Does anyone know the temperature that a first gen (03) catalytic converter runs at?
Discussion in 'Technical Chat' started by Taylor, Mar 15, 2013.
  1. Mar 15, 2013 at 7:12 PM
    Taylor
    Taylor [OP] Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I just threw a PO420 code today on the way to work.
    I haven't had a chance to check my MAF, gas cap, or exhaust leaks. I really trust the batch of gas I have, and I don't smell any rotten eggs, but I'd like to be certain.
    I ran seafoam about 400 miles ago and I want to make sure I didn't clog my cats. I know you can use a laser thermometer and measure the temp of your cats at running temperature to see if they work. Does anyone know these numbers? Thanks!
  2. Mar 15, 2013 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    depending on load, they can run 500-700* at idle, and 1200-1500* driving.
  3. Mar 15, 2013 at 7:53 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Thanks!
  4. Mar 16, 2013 at 7:49 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    If you would have clogged your cats, you would notice a loss of power. It is possible the catalysts are just weak from age/wear. The running temps will be lower with weakened cats. There really isn't a printed spec for this value either, but the values given above are generally what you might see. Looks like you already know to check for exhaust leaks. The gas cap and MAF values will not cause a catalyst code either. MAF can cause rich or lean codes, and the gas cap can cause EVAP codes.
  5. Mar 16, 2013 at 7:55 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Thanks, I'll keep that in mind. That's what I hate about only having this a few months. I'm still not 100% sure what's "right" when it comes to how this truck behaves. I could hear or feel when something was wrong with my old taco, but this new one is odd to me. I can't tell if I'm low on power, if that's how it's always been, or if it's all in my head. I'm getting my best gas mileage ever so far, so I don't think I'm running rich or lean.
    I smelled my exhaust today and it smelled vaguely sulphur-y, but then again, I've never smelled it normally, so I don't know what's "normal".
  6. Mar 16, 2013 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    bongo. The temps I listed are very general. Ive seen temps as low as 300* under little to no loads, and as high as 1800* under load, and WOT.
  7. Mar 16, 2013 at 8:48 PM
    BamaToy1997
    Bill
    Navarre, FL
    Looks like it is finally time for me to write that thread on the Toyota P0420 code and how to diagnose it.
  8. Mar 17, 2013 at 5:02 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Isn't 420 the heater circuit for the sensor?
  9. Mar 17, 2013 at 7:36 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    no that is a different code
    again, most likely cause on an 03, in 2013...?
    o2 sensor is used up. cats are likely fine. correct diagnosis saves
    time a trouble guessing of course, but all o2 sensors have a finite
    life typically somewhere in the 110,000-160,000 mile range
    seafoam likely coated the sensor with added mung and shortened it's life
  10. Mar 17, 2013 at 1:51 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Yes please!
    Also, the CEL/MIL went out today, so I guess it stopped throwing the code?
    Yesterday I pulled the air filter and inspected it ( for no reason ), re-tightened my gas cap, and fiddle with the sensor wires. Then I drove about 30 miles to hit some range. Light was still on.
    Started the truck up this morning and drove to work and back and the light never came on.
