Does anyone know what kind of wheels these are?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baflleje1, Jun 29, 2015.
  1. Jun 29, 2015 at 8:43 AM
    baflleje1
    baflleje1 [OP] New Member
    Brad
    2010 Tacoma TRD
    3 inch lift, 33 inch tires
    All of the center caps are missing. I'd like to replace them but I don't know who made them.
  2. Jun 29, 2015 at 8:51 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Pull a wheel off. The manufacturers usually stamp identifying numbers on either the inside lip of the wheel (where you'd pound a weight on), the inside of the drum, the back side of the spokes, or the inside face of the hub. Locations vary depending on manufacturer and wheel material (steel or alloy, etc)
    Should have the manufacturer's name, and the model # of the wheels. A quick google search should give you the info you need to source replacement center caps.
  3. Jun 29, 2015 at 3:08 PM
    baflleje1
    Brad
    2010 Tacoma TRD
    Thanks for the reply but I couldn't find any markings at all.
  4. Jun 29, 2015 at 4:09 PM
    Noelie84
    Noel
    Wales, Maine
    Hm. That's not a good sign...
    Could mean that the wheels are stamped between the lips (where you can't see them unless you pull a tire off)
    Urk.
    They look like aluminum? Either painted or with a matte finish?
  5. Jun 29, 2015 at 5:09 PM
    baflleje1
    Brad
    2010 Tacoma TRD
    They're definitely aluminum. Machine finished, I think.
  6. Jun 29, 2015 at 11:02 PM
    1slowvq37
    1slowvq37 Well-Known Member
    Jose
    Tecate BC MX / Chula Vista CA
    bone stock superwhite trd sport
    new car smell pine
  7. Jun 30, 2015 at 8:45 AM
    baflleje1
    Brad
    2010 Tacoma TRD
    Wow! I have no idea how you found those but Thanks!
  8. Jun 30, 2015 at 9:42 AM
    mcgov303
    mcgov303 I'd rather be in the mountains
    Denver
    2015 BRM TRD Off Road 4x4
    Toytec 3" w/ AAL, Leer 100R, 16" SCS F5s, 265/75 KO2s, pro grille, cmc
    They don't look the same, the OP pic has 6 holes while the MB wheel link only has 5
  9. Jun 30, 2015 at 9:46 AM
    Noelie84
    Noel
    Wales, Maine
  10. Jun 30, 2015 at 9:50 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^The 6-lug version of MB252 matches baflleje1's:
    @baflleje1: Looks like the wheel comes with generic can-shaped center caps, which you can buy at most auto parts stores. No need to order from MB.
  11. Jun 30, 2015 at 10:53 AM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    Definitely not true there. Each manufacturer may do things differently in how they attach to the wheel ... push-thru, snap-on, etc. Is the center bore different that it requires something unique, and so on. Why waste money on something that will fit poorly, only to lose them soon after because you took the cheap route.
    Best bet is to try contacting MB directly (email only) or their retail end @ Discount Tire. See if they can provide the center cap number for that wheel since it is a discontinued model. Take that number and check http://www.centercapsdirect.com/MB-Motoring-Wheels_bymfg_830-0-1.html here. I have tracked down countless caps here over the past few years.
