Does anyone know what oil came with a 2010 AC four cylinder/automatic
Discussion in '4 Cylinder' started by Taco.Tim, May 5, 2010.
  1. May 5, 2010 at 6:58 PM
    Taco.Tim
    Taco.Tim [OP] Well-Known Member
    Tim
    Georgia
    2010 Buhlue Access Cab 2WD
    Looking!
    Hi all,
    I went to a new owner deal at the Toyota dealership tonight, and noticed a lot of the cars on the lot now have stickers showing the cars have 0/20 synthetic oil. The speaker for the service department mentioned that also, and said some 2010 Toyotas came with the synthetic, and some came with regular oil. My oil cap shows 0-20 and 5-20, so I am still not sure what it came with. When our truck was delivered ( I ordered it via telephone, then came in and paid a deposit in October and picked it up in December ), the stickers had already been removed.
    Is there a definitive answer? Just curious really, but it would make a difference in the interval when I change the oil.
    Thanks,
    Tim Glover
  2. May 5, 2010 at 9:07 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Regardless, I would still change the initial fill at 5K if not sooner.
  3. May 5, 2010 at 9:09 PM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    No change it to either the 0w20 or 5w20 it won't hurt your truck. I use mobile1 syn and filter...I change my oil every8500 miles 5w20
  4. May 6, 2010 at 7:51 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I use Dino 5W-20 and have it changed every 3500 miles.
  5. May 9, 2010 at 6:24 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    When I bought my 2010 Prerunner 3 weeks ago, I got from Toyota 2 years or 25,000 miles which ever comes first of free oil changes every 5000 miles. Going to ask about the 0-20 when I take it in for the first time. I did see the last time I was at Walmart that Mobil-1 did have 0-20 and it said for better gas mileage.
  6. May 11, 2010 at 6:07 PM
    old dad
    old dad Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    does everybody pretty much use the recommended 5w-20, I'm used to running 10w-30 in the now deceased silverado. Should I stay with the 5w-20?
    mark
  7. May 11, 2010 at 9:27 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    Most will tell you to stick to the 5W-20 and 0W-20 for warranty purposes but the owners manual does have ambiguous wording that other weights can be used in higher heat climates.
    5W-20 was mainly spec'd for mileage requirements. If you have a leftover stash of 10W-30, would say use it and just switch over to 5W-20 when convenient.
  8. May 11, 2010 at 9:32 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    i would use 0w20 for best cold start and mpg and change at 5k for warranty purposes and longevity of your engine.
  9. Jul 18, 2013 at 5:01 PM
    TOYOTA FREAK
    TOYOTA FREAK Member
    ORLANDO
    BASE TACOMA SR5 4 CYL
    New wheels and tires,from 15" to 19"
    Hello Tim,the 0-20 is synthetic from Toyota and also synthetic from Mobil 1,if your truck uses 0-20,the 5-20 is easier to find,but Toyota on my 2012 4cilinder recommends to use 0-20 and when I can't find it 5-20 but to change it on the next oil change. I am using 0-20 on a 4cilinder,it works fine and changes are every 5000,my wife 6cilinder 2012 Highlander uses 0-20 and it is change every 10000. Hope this helps a little. Take care.
