Does anyone know what skids to remove for dealer transmission flush?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbraumb11, Oct 4, 2023.
  1. Oct 4, 2023 at 7:50 PM
    tbraumb11
    tbraumb11 [OP] Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    2015 trd sport full skids (front, transmission and transfer case)
    Just trying to avoid skid plate fees and don't want dealer touching more than they have to.
  2. Oct 4, 2023 at 7:52 PM
    Bishop84
    Bishop84 Well-Known Member
    You need to ask them.
    Most dealers do spill and fill, so just need access to pan and side of trans.
    A proper flush with inline means we need access to lower rad (engine plate) and trans pan (trans plate) to set/check the level after.
  3. Oct 4, 2023 at 8:43 PM
    tbraumb11
    nanaimo
    what are those?
    It's a proper flush with the machine they said, they don't do drain and fill.
    Sounds like if I remove front and mid I would be fine.
    Bishop84 likes this.
  4. Oct 4, 2023 at 8:55 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I really would not get a flush. The pressure they use to flush can harm a tranny. I would highly recommend just a drain and fill every 50K miles. Do a little googling on the subject. Good luck.
  5. Oct 4, 2023 at 9:02 PM
    tbraumb11
    nanaimo
    what are those?
    This is my first flush I have 115 000 km on my truck not miles (flush should have been done around 90k) I have heard flushes are not great for high milage but should be fine if it's my first once it gets higher is when you want to look at drain and fill.
    Correct me if I am wrong.
  6. Oct 5, 2023 at 4:11 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Use the search function.
  7. Oct 5, 2023 at 7:46 AM
    tbraumb11
    nanaimo
    what are those?
    I have searched the topic and found arguments for both sides I surf this site a lot
