does anyone know what this means??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rewert2010, Feb 7, 2012.
  1. Feb 7, 2012 at 9:32 PM
    rewert2010
    rewert2010 [OP] Member
    ryan
    94556
    10 PreRunner SR5 mag gray
    Every time i turn on the engine a red image next to the "maintenance required" light starts blinking for about 5 seconds and then goes off. does anyone know what this means? thanks for the help!IMG_1303.jpg
  2. Feb 7, 2012 at 9:33 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    air bag light?
  3. Feb 7, 2012 at 9:33 PM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    Its your airbag light... I wouldn't be concerned unless it stays on.
  4. Feb 7, 2012 at 9:34 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    May need to be reset. If it is staying on that is.
  5. Feb 7, 2012 at 9:36 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    mine flashes for about that length when i turn my truck on and then shuts off too, be worried if it stays on
  6. Feb 8, 2012 at 12:02 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you look closely at it, it clearly looks like a seated pregnant woman. The light means just that, she's preggers! The light will flash one time per baby, as in 5 flashes means quintuplets. Congratulations! Hope that's a double cab!;)
  7. Feb 8, 2012 at 12:09 AM
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    :rofl:
    OMG I can't stop laughing.. that made my night :D
  8. Feb 8, 2012 at 12:20 AM
    Royce99
    Royce99 Taco Samurai
    Royce
    Houston
    2012 MGM Prerunner SR5 Debadged
    Just getting started.
    If it's on the internet it must be true...:eek:
  9. Feb 8, 2012 at 12:22 AM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    everything on the internet is true:eek: :p
  10. Feb 8, 2012 at 12:23 AM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    it means your clock spring is bad or going bad. Mine got replaced under my 100000 mile warranty, would have cost me 300 bucks, while it was in the shop they found a few oil leaks and fixed them, another 2700 that it saved me.
  11. Feb 8, 2012 at 9:55 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 2005's clock spring went bad (the air bag light came on) without any prior warning or brief flashing, etc. :eek:
    That was in 2008 and was about $300 to fix then. The only 'failure' I had to pay for... (other than fixing the harsh ride from the too soft rear springs, the dealer didn't offer to fix or tell me about a TSB... this was before I joined TW). :rolleyes:
  12. Feb 8, 2012 at 10:38 AM
    superbikedad
    superbikedad Active Member
    Jeff
    Lake Stevens, Washington
    07 sr5 trd dbl cb 4x4
    Bilstein 5100's, 1.75 lift front, 1' block rear,265/70/16
    Im confused...is the airbag light supposed to blink after you start the truck or does that mean there is a problem? And if it does blink... how many times?
  13. Feb 8, 2012 at 10:44 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    It is probabally going through the self check proces.
  14. Feb 8, 2012 at 3:00 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    If it just blinks when you start the truck and then goes out, you're fine. A lot of lights come on with start-up. If it continues to blink or stays on, they you have an issue.
    I know many have had the clock spring problem. I did not. However, I had a friend ride in my truck a few times, and let him drive a few times. Every time he did, the air bag light would come on and the system was shut off. He's a BIG guy and it would actually register as the vehicle being in an accident. (Airbags didn't deploy though.) Practically weekly trips to dealer to have them recalibrate.
  15. Feb 8, 2012 at 4:41 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    And here I thought it meant it was time to read the manual.
    Hmmmm....preggers eh?
    I think I'll just pull that bulb.
  16. Feb 8, 2012 at 4:52 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    you aint kidden....lmao
  17. Feb 8, 2012 at 5:42 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Too late for that now.:D
    I'm glad you guys saw the humour in that. :cool:
