Does anyone make a 4.5-6" lift that doesn't require cutting the x-member?
Discussion in 'Suspension' started by hookedontronics, Jul 1, 2010.
  1. Jul 1, 2010 at 10:22 PM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I'd really like to get a 4.5 or 6" lift but I am not to fond of cuttin the crossmember on a truck that's not even two months old. Does anyone make one? Or is cutting the xmember really not that bad. I know once you do it you can never go back...
  2. Jul 1, 2010 at 10:24 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Nobody makes a kit that doesn't have to cut the cross-member to get that much lift. I know if you cut the crossmember, you could always buy another factory cross-member if you ever wanted to go back to stock. I wouldn't want to do it until the warranty ran out, but that's just my opinion. :)
  3. Jul 1, 2010 at 10:29 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    nope, and my cross member is cut...scary idea at first but really not the bad
  4. Jul 2, 2010 at 8:35 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    FWIW, You CAN go back. I recently got rid of a 6" DB lift on my 1st Gen Taco. Including welding #2 crossmemebr back in. Now has 'only' King CO's and rear AAL w/5100's. (Much better now).
  5. Jul 2, 2010 at 8:39 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    are you 4x4 or 2wd? if 2wd you can get spindles
  6. Jul 2, 2010 at 10:05 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    YOu have to cut the cross member because anything more that 3" requires a drop bracket (unless you have a prerunner). The drop bracket kit also relocates the front diff. It lowers it to maintain the front CV angles, But you still have to connect the front drive shaft from the T-case to the Diff. In a stock 4x4 truck the front drive shaft goes over the cross member, but will hit the cross member when the diff is lowered, so the cross member has to be cut to provide clearance for the front drive shaft. Prerunners require no cutting for a drop bracket or spindles. Cutting the cross member is not that difficult. I just did solus' not too long ago. We just used a sawzall. Just make sure you lubricate the blade or you will dull it out very fast.
  7. Jul 2, 2010 at 10:41 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    if your 2wd the procomp db lift does not require you to cut cross member
  8. Jul 2, 2010 at 3:54 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    X2, camburg spindles give 4" of lift and then get coilovers or 5100's and put them around 2" and you will get 6" total, then you just have to do something for the back, like a custom leaf pack from alcan for $500. But only of your a Prerunner.
