Does anyone recognize this noise? (video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iroh, May 18, 2013.
  1. May 18, 2013 at 7:06 PM
    iroh
    iroh [OP] Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I'm hoping for help narrowing this one down. Maybe someone else has run into this before.
    Wait for when the camera is in the middle of the cab.
    http://youtu.be/U3ZeRxcevi4
    Temperature-related change: it gets quieter when ambient temp is cold. Nonexistent below freezing. It didn't do it when I bought the truck (winter) and it's most apparent when the temp is 80+.
    Speed: I can hear it from 40-on up if I turn the cabin fan off, but it's most evident between 55-60 mph. Strangely enough the pitch never changes; it's always that warbled sound and it doesn't get higher or lower.
    Steering: the cycle speed of the sound gets faster when turning right, slower when turning left, but the noise doesn't change volume either way. Doesn't sound like any bad wheel bearing I've ever heard. There's no growl and the pitch is constant.
    It will completely disappear if I go over a small bridge that picks the truck up a little bit.
    U-joints feel tight and are greased, no vibes at all, wheel bearings silent if truck picked up and they're spun. Front wheel bearings replaced by dealer before I bought the truck, and I'm wondering if it could be the tires because they have some odd wear on the inside shoulder thanks to the old bearings' sloppiness.
    I can't feel play in the rear bearings and the seals aren't leaking any diff fluid. Maybe it's just early on in its problem? But the sound seems to come from somewhere forward, not aft.
    I first heard it about 3k miles ago and it hasn't changed significantly, although I think it might be louder when I take the tires above 40 psi. They're at 38 cold during video. Lug nuts are freshly checked at 80 ft-lb.
    Could driveline angle do something whacky like this? The center bearing rubber has a fair amount of sag in it and the factory leaf springs aren't as perky as a fresh set. Although, the turning thing doesn't match.
    Like I said before, has anyone heard this noise?
  2. May 18, 2013 at 7:15 PM
    iroh
    michigander
    tonneau
    Forgot a couple things....
    No change if I put it in 4WD.
    No change if tranny put in neutral, no change if I'm in 4th gear or 3rd gear.
    The noise is not load-dependent. It happens if I'm accelerating, cruising, coasting, decelerating in gear, whatever.
  3. May 18, 2013 at 9:16 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i dunno, check for wind related, loose mudflaps, motor protector rubber things etc. i dunno
  4. May 18, 2013 at 9:24 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Jeezus, I wish my truck was that quiet.. srry man I got nothing
  5. May 19, 2013 at 11:01 AM
    iroh
    michigander
    tonneau
    I didn't see anything loose other than the front skid missing a bolt I broke and haven't gotten around to fixing yet other than the ziptie band-aid.
    Well if anyone has any more ideas it would be appreciated.
    Otherwise I suppose I'll continue my current plan... change out tires, if it still makes the noise then put up with it until it's bad enough to pinpoint. As it is the radio doesn't have to be very loud to drown it out.
  6. May 19, 2013 at 12:34 PM
    92dlxman
    Kevin
    Visalia, CA
    my truck was doing a weird kind of buffeting noise between 50 and 60mph. I don't notice it anymore. think it was wind related
  7. May 19, 2013 at 5:50 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Maybe the center support bearing on the rear shaft is whining at you. Really hard to diagnose it just by looking at it, or even shaking it, because the bushing that surrounds it gives. If you can attach your camera underneath your truck somehow, record, and replicate the noise, you may be able to narrow down where your problem is.
  8. May 19, 2013 at 7:04 PM
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    I was thinking it was carrier bearing related as well. It sounds driveshaft related to me
  9. May 21, 2013 at 3:24 PM
    iroh
    michigander
    tonneau
    I think you guys are right. I crawled under the truck after I got home and the driveshaft on both sides of the carrier bearing was too hot to touch.
    Looks like I'm about to have an expensive weekend.
  10. May 21, 2013 at 3:29 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Wow, check the u joint there too. Advance auto has the bearing for about $60, and moog u joints run about $20. If you order online and pick up in store, you can throw 15% off at least.
  11. May 21, 2013 at 3:57 PM
    iroh
    michigander
    tonneau
    Yeah, it's got sag, probably from the heat. Hopefully the driveline shop up in GR can hook me up.
  12. May 21, 2013 at 4:00 PM
    iroh
    michigander
    tonneau
    I tried the advance auto site but it wouldn't give me bupkis for exact fit. Maybe I screwed up somewhere.
    Yeah, that u-joint is probably cooked. It's not loose but it's going to have to come out anyways.
    I know what the dealer would say.... $400+.... I could go one piece for that.
  13. May 21, 2013 at 4:18 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    This is the one you need http://shop.advanceautoparts.com/we...hicleIdSearch=-1&searchTerm=934401&showTitle= it says $67, but throw a discount code in, and you got a win. And don't worry bout their fit check, it's not always right. Cross reference other sites if you don't feel comfortable.
  14. May 21, 2013 at 4:25 PM
    cmanhonor
    cmanhonor Well-Known Member
    Artem
    Colorado
    21 Tundra DC
    You might also want to check out the "wookie strength carrier bearing mod" lol
  15. May 31, 2013 at 9:00 AM
    iroh
    michigander
    tonneau
    Update for the archives... I rotated the tires in an "X" pattern today just for the heck of it. The noise is completely gone! I drove a good 30 miles at its most excitable speed - nothing. Just sweet sweet bliss, and the bit of 5th gear whine the R155 tranny is good for. Relief at last!
    Now I have yet another excuse for getting those LTX MS/2 tires this year.
