Does anyone slackline?
Discussion in 'Sports, Hobbies & Interests' started by crazyengineer, Sep 23, 2011.
  1. Sep 23, 2011 at 5:35 PM
    crazyengineer
    crazyengineer [OP] Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    I just started learning to slackline like 2 weeks ago, does anyone else slackline?
  2. Sep 23, 2011 at 5:41 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    wtf is slackline?
    :confused:
  3. Sep 23, 2011 at 5:45 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    x10000:confused:
    edit: are you talking about zip-lineing?
  4. Sep 23, 2011 at 5:47 PM
    97yota4wd
    Eric
    Mesa, AZ
  5. Sep 23, 2011 at 5:56 PM
    crazyengineer
    patrick
    Bristol, TN
    1 inch (usually) tubular webbing, usually the mil-spec stuff stretched tightly between 2 anchor points and then walk on it
    can be between 2 trees which is common, a few feet high
    its a lot of fun
    check out youtube, just search slackline
    in reality though, the slacklines can be put an any height, but mostly they are low. and there ar 2 inch lines as well, but they have come about more in the recent years and they are more of trick lines
  6. Sep 23, 2011 at 5:56 PM
    crazyengineer
    patrick
    Bristol, TN
    yes, that is a slackline
  7. Sep 23, 2011 at 6:28 PM
    crazyengineer
    patrick
    Bristol, TN
    Surely there is someone who has slacklined here
  8. Sep 23, 2011 at 6:31 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    ive never done it but that is badass dude! mad props to anyone that does that with or without the safety line or whatever they call it. I was watching universal adventure sports or whatever and there was a guy doing it without a safety line over like a canyon and....:eek: that was crazy
  9. Sep 23, 2011 at 6:52 PM
    crazyengineer
    patrick
    Bristol, TN
    we do it between a couple trees, the highest we ever go is like 5 ft, usually around 3 though
    its a lot of fun, and surprisingly cheaper to set up than you would expect
  10. Sep 23, 2011 at 6:55 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    That looks dangerous!
  11. Sep 23, 2011 at 6:55 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    Cool. It looks pretty challenging. I've got feet upon feet of 1" tubular webbing from SAR. I might have to try it out... :)
  12. Sep 23, 2011 at 6:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    all my crossings have me in a swiss seat and carabiners :anonymous:
    that looks fun though
  13. Sep 23, 2011 at 7:00 PM
    crazyengineer
    patrick
    Bristol, TN
    ya need carabiners for a mechanical advantage to get it tight enough, check out Youtube videos of how to set them up, once you get used to the feeling of being on the line it is a lot easier, i am almost to a point where i can stand on it (not walk yet though)
  14. Sep 23, 2011 at 7:02 PM
    crazyengineer
    patrick
    Bristol, TN
    thats why we use mine no more than 5 ft above the ground
    since i am still learning, i use no more than 3 ft
    no "Need" to cross things
  15. Sep 23, 2011 at 7:06 PM
    Slodgetto
    Silas
    Dirty Terc
    Gotcha. I got a few 'biners lying around.... lol
  16. Sep 23, 2011 at 7:07 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
  17. Sep 23, 2011 at 7:16 PM
    crazyengineer
    patrick
    Bristol, TN
    well how mine is done is it has a loop tied in one end and in the other end
    it is weaved through 4 carabiners for a mechanical advantage and it stops it from loosening
    here is a diagram of how mine is set up except there are four carabiners except 2
    http://www.lookatmypage.net/doings/slackline/slackline.gif
    other people do it different ways, the 2 inch trick lines have ratchets to tighten them though
  18. Sep 23, 2011 at 7:19 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i was working as an arborist/tree surgeon for a while. we just used a 2" heavy duty ratchet strap when we were waiting for wind to die down before climbing or felling
  19. Sep 23, 2011 at 7:29 PM
    crazyengineer
    patrick
    Bristol, TN
    i think that is where the trick lines came from actually, the ratchets are basically the same
    it started with a bunch of climbers getting bored and having their 1 inch tubular webbing decided to try something new (or at least thats what i was told)
    anyways, how did the ratchet strap work?
  20. Sep 23, 2011 at 7:38 PM
    Yoytoda
    Roland
    completely stock
    worked fine...
    set it up with the ratchet upside down
    if right side up the weight of the handle will twist the strap
