Does cylinder position matter for startup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, May 6, 2016.
  1. May 6, 2016 at 4:09 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    My inclination is that yes, the position cylinders and therefore crankshaft does matter and that, if the crankshaft has been turned manually for testing purposes (e.g. a cylinder leakdown test), one of the cylinders needs to be reset to TDC in order for the startup to run properly, i.e. not misfire. Can you (dis)confirm this guess of mine ? Also, if I am correct, can you tell what cylinder position is required, in other words, which of the 6 needs to be in TDC ? Does it correspond to the firing order, where the front right (passengers) side fires first and therefore should be in TDC before starting the engine after manually turning the crankshaft?
  2. May 6, 2016 at 4:13 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    No. Your engine doesn't stop your pistons at the same position every time you turn your engine off.
    foampile[OP] likes this.
  3. May 6, 2016 at 4:19 PM
    foampile
    Mid-Atlantic
    Ok. I thought I may have read somewhere that the ECU makes sure they stop in the same position it expects them to be in when it starts the engine. Maybe wrong...
  4. May 6, 2016 at 4:43 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you had moved the crank without moving the cams (ie you had the timing chain off) then you would have issues.... otherwise no, you can spin the motor to your hearts content and it will fire up regardless of where you position it.
