Does Gas matter???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by squatpuke, May 10, 2018.
  1. May 10, 2018 at 11:22 AM
    squatpuke
    squatpuke [OP] Member
    Larry
    Flagstaff, AZ
    2018 Inferno Off Road
    Sorry I haven't really searched much on this topic (suspect there is a thread somewhere) and I hope I'm not opening up a can of worms by asking...
    I just bought my 2018 Taco a few weeks ago and it's time for my FIRST fill-up.
    I always buy 87 octane in my used sedans (this Taco is my first NEW car)...and want to continue doing so because I am a cheap-skate. (I had an 87 4-Runner that never gave me any fuel system issues)
    What are the pros/cons of high/low fuel octanes in today's taco engine?
    As well, do you guys run those expensive pour-in cleaners thru the fuel system occasionally? I suspect the fuel system would get dirtier with 87 gasoline...? Recommendations??
    Be gentle with me and this noob question.
    Thanks all.
  2. May 10, 2018 at 11:26 AM
    su.b.rat
    su.b.rat broken truck
    runs fine on 87.
    but if you want to upgrade your ECU software for driveability improvements, then you'll have the option for either 91/93oct or 87, and then it matters. referring to the OV Tunes, your can find threads here in 3rd gen. 91 performs differently than 87 in that case.
  3. May 10, 2018 at 11:28 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Run 87, and rest a little easier at night knowing your wallet won't try to kill you in your sleep.
  4. May 10, 2018 at 11:31 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    My truck runs like shit on 87. It lugs and chugs terribly. 93 makes it run smooth as silk.
    MikeyMcFly and gilligoon like this.
  5. May 10, 2018 at 11:33 AM
    phsycle
    phsycle Well-Known Member
    CA
    Anything above regular: Pros - Truck performs exactly the same as regular. Cons: Less gas money.
    I run regular, which around here is 85. Runs perfect.
    I don't run any fuel additives. History says they either don't work or may even cause more damage/gunk. Go to a quality gas station. Most use good detergents that will leave your engine clean.
    DubfromGA and cshrum like this.
  6. May 10, 2018 at 11:34 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    235K miles of Costco 87 in my 01. Not a single issue.
    My 17 PRO and 18 SR both get 87 Costco. I run the same in my LX570
    If you see the gas that are being put in Hilux and Land Cruiser around the world, and still seeing 400K miles without needing an overhaul, you will realize that we over maintain our cars in the USA..and any USA gas is fine for our Toyota vehicles....
  7. May 10, 2018 at 11:35 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Toyota’s run fine on 87,we can argue how they fudge the numbers anyway. If thy don’t, run well it’s a tuning or maintenance issue more likely than a gas issue typically.
    DubfromGA likes this.
  8. May 10, 2018 at 11:36 AM
    phsycle
    CA
    I believe, if the LX is anything like the LC, Premium is recommended. I still ran regular in the LC without issues. Even towing heavy loads, no pinging.
  9. May 10, 2018 at 11:37 AM
    PROseur
    Pussy
    Yes it is. But I have been running 87, on all my LX, since my first LX 450 in the 90s....
    Heck my new RCF is getting 87 too. And I know manual says 91. Oh well.
    I only run 100+ octane when I am at the track, and actually using the higher octane. Rest of the time, 87 in everything.
    When in Idaho, I even run 85.
    DubfromGA and phsycle[QUOTED] like this.
  10. May 10, 2018 at 11:37 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would love to find Ethanol Free Gasoline to put in my Truck...
    Pella, CMD-KY, Riding Dirty and 2 others like this.
  11. May 10, 2018 at 11:41 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I tried 91 in the Tacoma for a few tanks, no difference in MPG or power. The Highlander needed 91. I always thought it was underpowered.
  12. May 10, 2018 at 11:42 AM
    Lt. Dangle
    Ohio
    Only place by me that has it is a Marina. That is not the place to buy gas...
    tacoguy88 and shakerhood[QUOTED] like this.
  13. May 10, 2018 at 11:44 AM
    shakerhood
    Southern Ohio
    I looked on some website before and the closest place to me was almost 100 miles, might have been a Marina too lol.
  14. May 10, 2018 at 11:46 AM
    squatpuke
    Larry
    Flagstaff, AZ
    Thanks everyone...Looking forward to the $60+ dollar fill up of 87 later today...
    (I'm used to a meek $25-30 dollar fill-up on my 05 Honda accord, along with 2 weeks between fills...steep Tacoma learning curve here!!)
    mmrocek likes this.
  15. May 10, 2018 at 11:48 AM
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    I have always wondered about 85. Given that the manual says at least 87 I run the midgrade around here.
  16. May 10, 2018 at 11:48 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Waste of money in a car but in small engines like my atvs I only run non ethanol since they tend to sit longer. Ethanol definitely affects the small engines
    Clearwater Bill likes this.
  17. May 10, 2018 at 11:49 AM
    PROseur
    Pussy
    I put 2700 miles on my 17 PRO with 85 in it, while driving through Idaho and the states around it. No issues at 85MPH in the 6MT.
    bensonxj[QUOTED] likes this.
  18. May 10, 2018 at 11:50 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yeah - you and me both. Some trucks do this and some don't - I've driven friends (and am in a loaner now while my diff is getting replaced) and they run decent on 87 no problem. My truck feels 1000lbs heavier on 87 and gets that slight miss feeling when it lugs in 5th or 6th and I'm trying to accelerate at slow speeds. on premium this isn't an issue...
    Lt. Dangle[QUOTED] likes this.
  19. May 10, 2018 at 11:51 AM
    Lt. Dangle
    Ohio
    Yeah, my chainsaw, lawn mower, and pressure washer all recommend e free gas. Lawn mower and pressure washer deal with it. I buy the canned stuff for my saw.
  20. May 10, 2018 at 11:51 AM
    rnish
    Tacoma 2nd gen
    OP. While we are obsessing about gas. I try to keep my tank above 1/4 full. The fuel pump is in the gas tank and the gas keeps the pump temp down.
    DubfromGA, cshrum and squatpuke[OP] like this.
