Does Gas matter???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by squatpuke, May 10, 2018.
  1. May 10, 2018 at 12:39 PM
    #41
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Use whatever octane rating the manufacturer specifies.
    YOU GET NOTHING IN TERMS OF HORSEPOWER, PERFORMANCE OR FUEL ECONOMY BY USING HIGHER OCTANE FUEL. PERIOD.
    You might get different/better detergents, but that's it. Not worth it for frequent use.
    tacoguy88 likes this.
  2. May 10, 2018 at 12:39 PM
    #42
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    lol these threads are always a shit show of mis-information
    Lt. Dangle likes this.
  3. May 10, 2018 at 1:06 PM
    #43
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Sorta like oil threads
  4. May 10, 2018 at 1:16 PM
    #44
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Gas Lies Matter.
  5. May 10, 2018 at 1:33 PM
    #45
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    You could use 87 Top Tier gas like the people who wrote the owner's manual say. Top Tier gas is just like other gas but with added detergents. But what would Toyota know?
    squatpuke[OP] likes this.
  6. May 10, 2018 at 2:35 PM
    #46
    CTF
    CTF Well-Known Member
    2017 TRD OR
    I have an ‘06 V6 Tacoma and a 2017. Yes, higher octane definitely causes a noticeable change in the way both run. They both shift more predictively and MPG seems to be slightly better as well. That being said, some brands seem to be better for the ‘06. Like Shell 93. The 2017 seems to do well with 89 from Marathon. Those who disagree need to have their rear end aligned.
    bshammer0 likes this.
  7. May 10, 2018 at 2:49 PM
    #47
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    I find that my truck runs very poorly when it doesn't have gas in it, so I put gas in it and it runs much better
  8. May 10, 2018 at 3:04 PM
    #48
    squatpuke
    squatpuke [OP] Member
    Larry
    Flagstaff, AZ
    2018 Inferno Off Road
    Interesting...did not know that. Good tip.
  9. May 10, 2018 at 3:14 PM
    #49
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    In case of apocalypse, I’m not giving you a ride! I hardly ever let it go below 1/3 or so, like to be able to drive to the next gas station. Its a 4-wheeling habit.
  10. May 10, 2018 at 3:29 PM
    #50
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Regular. Everytime.
  11. May 10, 2018 at 3:51 PM
    #51
    OnHartung'sRoad
    I swear the tank must be triangle shaped with a pointy end facing down - it just seems that the guage drops so much faster after it drops past 1/2 full!
    HutchJ likes this.
  12. May 11, 2018 at 11:23 AM
    #52
    STexaslovestacos
    Sam
    2017 MT TRD OR
    They all do that, it's because of how the floats used to measure it the level work. You can fill the tank all the way to the top, but it won't actually register the level dropping until it's gone past the diameter of the float and the float actually starts to sink. That's why "full" can last for a few gallons.
  13. May 11, 2018 at 11:26 AM
    #53
    rhallmcp
    rhallmcp Well-Known Member
    Upstate NY
    2018 Trd Pro
    it was engineered to run on regular unleaded. Thats all you need to know.
    its not a high compression performance engine which would require higher octane.
    tacoguy88 and PROseur like this.
  14. May 11, 2018 at 11:32 AM
    #54
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    My best friend works for a gas distributor. They sell to many different gas stations, big names too. It all comes from one main tank and they have additive stations that pour said additive for said gas station.
    When was the last time you saw a Chevron gas truck, delivering to a Chevron ? You don't, if you ever see the Name brand gas trucks , they are bringing their additives to a distributor like my friend...
    PROseur likes this.
  15. May 11, 2018 at 12:28 PM
    #55
    GR8APE
    GR8APE Well-Known Member
    The higher octane rating for me has made only a slight difference in gas mileage but not enough to justify the price difference. Ethanol free gas however does give me better gas mileage but it also is much more expensive around here and doesn't seem worth the trouble. I have found though that name brand fuels seem to make my truck run smoother and I have noticed a slight increase in mpg.
  16. May 11, 2018 at 12:37 PM
    #56
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    87 octane will work fine in your truck. I would highly recommend purchasing your fuel from a "Top Tier" station.
    A fuel cleaning additive once a year will do fine. Put it in the tank about 500 miles prior to your oil change. Make sure the cleaner contains PEA. Two very good fuel system cleaning products are Redline S-1 and Gumout All In One With Regane.
    https://www.toptiergas.com/
    https://www.toptiergas.com/licensedbrands/
  17. May 11, 2018 at 12:57 PM
    #57
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Only matters if you're in a room with other people.
    MrBrooks and PROseur like this.
  18. May 11, 2018 at 2:17 PM
    #58
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Canyon, Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid BlackSumos Bilstein 6112/5100
    Big time, fuel lines and carb diaphragms are no match in the long run.
  19. May 16, 2018 at 10:43 AM
    #59
    rideawalrus
    rideawalrus Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    Is the manual octane rating taking into account your elevation? I know regular octane at sea level is 87, yet in Colorado it's 85. So when the manual says use at least 87, do I have to use mid grade in Colorado which is 88?
  20. May 16, 2018 at 10:47 AM
    #60
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    I have been running mid grade. I figured the manual would have stated an exception if it was the case. From what I have read the use 85 at high elevations was more applicable to carbed engines rather than modern EFI.
