Does Gas matter???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by squatpuke, May 10, 2018.
  1. May 16, 2018 at 10:57 AM
    #61
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think it says 87 or Higher so you are good to go.
  2. May 16, 2018 at 11:00 AM
    #62
    SeeWhatHadHappenedWas...
    SeeWhatHadHappenedWas... Well-Known Member
    Jeremiah
    Oregon
    2017 OR DCSB MT Quicksand
    It says do not run 85 right on the gas cap
    GoldenTaco27 likes this.
  3. May 16, 2018 at 11:58 AM
    #63
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    That is for E85 not 85 octane I am pretty sure
    tacoguy88 likes this.
  4. May 16, 2018 at 12:49 PM
    #64
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    Just run top tier gasoline. Detergent matters more than octane. I have a few sources of good priced ethanol free near my home but I travel throughout some low population areas for work. So I keep this list to minimize fillups with potential subpar gasoline.(real bad gas will cause performance issues or even stop the vehicle in its tracks.)
    You can see the benefits here. Below Isthe current list. Costco is on this list..Sams club is not.
    https://www.toptiergas.com/licensedbrands/
    Now just use you tune system to guide you to the right station.
    TOP TIER™ Licensed Retail Brands76AlohaAmocoARCOBeaconBPBreak TimeCenexChevronChevron (El Salvador)Chevron (Guatemala)Chevron (Honduras)Chevron (Panama)CITGOConocoCo-opCo-op Premium Diesel (select locations only)Costco WholesaleCostco Wholesale - Diesel (select locations only)CountryMarkCountryMark PLUSDiamond ShamrockEssoExpress MartExxonFast FuelFast Stop - Diesel (select locations only)Fast Stop Express - Diesel (select locations only)G500 (Mexico)HeleHFN - Hawaii Fueling NetworkHolidayIrving OilKirkland Signature GasolineKirkland Signature - Diesel (select locations only)Kwik StarKwik TripKwik Trip ExpressMahaloMarathonMetro PetroMFA OilMobilMobil (Canada)OAAIOhana FuelsPetro-CanadaPhillips 66PUMA (El Salvador) PUMA (Panama)PUMA (Puerto Rico)QTQuikTripRangerRanger MustangRanger StallionRanger ThoroughbredReeder'sShamrockShellShell (Canada)Shell (Puerto Rico)SinclairSunocoSuperAmericaSuperFuelsTempo (Canada)TexacoTexaco (El Salvador)Texaco (Guatemala)Texaco (Honduras)Texaco (Panama)Tri-Par Qwik StopValeroWin Win
    shakerhood likes this.
  5. May 16, 2018 at 1:06 PM
    #65
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    You are likely ok to use 85 octane. If you are at high altitude there is less oxygen, therefore less compression and you don't have a turbo to compensate for the drop in compression. This is why 85 is available at high altitudes. What altitude above sea level are you at?
    Because of the high altitude you truck makes way less horsepower on most days than the trucks that run at sea level. Depending on how high up you are you could be only making as little as 220hp.
  6. May 16, 2018 at 1:08 PM
    #66
    silasvirus82
    silasvirus82 Well-Known Member
    NC
    3rd Gen Off-Road DCLB
    Hobie Fishing Edition
    Holy crap, the misinformation in here is comical. I can't believe there are people who have convinced themselves that higher octane gas makes their truck run smoother, or get better mileage. Higher octane gas is for engines with higher compression that require it. Putting 93 in an engine designed for 87 is just stupid and a total waste of money. Concerning brand name vs generic it's the same story. The EPA has minimum requirements for detergents that are pretty consistent across the board. Gas is gas, you're just a sucker if you think otherwise. For small engines or marine applications it's generally better to run ethanol free fuel since it has a much longer shelf life. The other reason is that older small engines are prone to corrosion from the ethanol, but even that has changed with most manufacturers now building their products to protect against corrosion. Do what you want, but a simple Google search could have answered your question.
  7. May 16, 2018 at 2:13 PM
    #67
    bensonxj
    2016 DCSB TRD Sport
    A lot of the higher grade gas here doesn’t have ethanol. Maybe that’s why the butt dyno and gas mileage is better for people.
  8. May 16, 2018 at 3:07 PM
    #68
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    All gas is equal at the refinery but only Top Tier gas has extra detergent (added at the refinery) beyond the federal standard for detergent.
  9. May 16, 2018 at 3:12 PM
    #69
    shakerhood
    Southern Ohio
    Whenever l can, I try to buy Top Tier Fuel like the Owners Manual says.
    Topanga Taco likes this.
  10. May 21, 2018 at 4:40 PM
    #70
    rideawalrus
    rideawalrus Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    I'm at about 6700ft
  11. May 21, 2018 at 4:55 PM
    #71
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    Yes, gas makes a huge difference. My truck won't go anywhere without it.
    Rick_Taco likes this.
  12. May 26, 2018 at 6:53 PM
    #72
    bill7549
    bill7549 Well-Known Member
    Bill
    2018 Tacoma TRD Pro Cavalry Blue
    Predator pro steps Victory 4x4 Blitz winch bumper WarnVR EVO 8-S winch
    My 2007 Taco SR5 initially ran great on 87. Summer of 2010 saw it start to spark knock like crazy. I switched to 93 and it ran great without problems, unless I tried 87 again. My 2018 runs fine on 87...for now.
  13. May 26, 2018 at 7:50 PM
    #73
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    Our engines are shared with Lexus. What I don’t understand why ours use 87 lexus use 93. for the first year of owning the truck I used 87 but I got curious and ran a few mid tanks and idk if it’s a coincidence but my gas mileage went up slightly about half a mile to a mile more per gallon and I did try going back to 87 and ran a few tanks as well and got about half a mile to a mile less per gallon. So I’m not sure I don’t really believe in the “power differences” and all the non sense with higher ocante fuel but I just can’t explain why it’s better with higher octane than other with 87
  14. May 26, 2018 at 7:57 PM
    #74
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    It depends on the level of stank in the tank.
  15. May 26, 2018 at 8:21 PM
    #75
    atlsmedic
    atlsmedic Kinda retired
    ATL
    2017 Black TRD OR
    Those fill-ups must get expensive.
  16. May 26, 2018 at 8:22 PM
    #76
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    All Gas Matters, don't trigger ppl
  17. May 26, 2018 at 10:37 PM
    #77
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Averages about $55 per fill up !!
