Does K&N cold air intake have any disadvantages to the vehicle ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoodratstormtroop, May 17, 2012.
Thread Status:
Not open for further replies.
  1. May 17, 2012 at 9:04 PM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
  2. May 17, 2012 at 9:06 PM
    BuckNakedBooda
    I actually just purchased and installed a Bullydog Watchdog a couple of weeks ago. Trying to adjust my driving habits and bump up my mileage a little bit. I have an Ulatraguage also but got tired of it...
  3. May 17, 2012 at 9:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That only works at WOT. IIRC, the new intakes have a "lean condition" only at WOT, correct? Do you remember what he said the AFR was?
  4. May 17, 2012 at 9:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The lean condition only affects WOT. My thoughts on it are this.....I think running more lean (12.5:1 or so) on a NA engine, "would" give more power, as the AF ratio is closer to ideal. However, it also increases heat. If you were under WOT conditions for extended periods, then I could see it being an issue. However, I dont see any issues arising from the new intake from a lean condition arising. On an SC'd engine, Yes. You want to keep the AFR's on the rich side, to more control heat, and detonation. But on the NA engine, I dont see it being an issue.
  5. May 17, 2012 at 9:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well.....To get the AFR's running more rich, then Yes.
  6. May 17, 2012 at 10:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought I saw somewhere that the new TRD INtake was near 12.5:1 or so @ WOT.
    A little off topic, but interesting none the less, Honda is developing some engines that run at an AFR of 25:1 at cruise, and between 15:1 and 17:1 under WOT!
  7. May 17, 2012 at 10:03 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    you are being timed :spy:
  8. May 17, 2012 at 10:15 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    the new airaid intake, closed box system also fits the 2012 Tacoma fyi :)
  9. May 17, 2012 at 10:20 PM
    08pretaco
    az
  10. May 17, 2012 at 10:24 PM
    08pretaco
    az
    Your kinda slow arent ya? Notice application on the link I posted....its a V6 :thumbsup: The kit comes with a pump relocation bracket.
    Your a very ignorant person you know that?
    Oh and it was installed on a V6, not my motor. People to install things on trucks other than their own...
  11. May 17, 2012 at 10:27 PM
    08pretaco
    az
    It is the new 2012 tacoma. notice on the lower middle...the blue bottle, that the power steering iirc..notice that little round thing to the right lower on it? That where the pump gets relocated to. Yes that is the 2012 motor in the picture
  12. May 17, 2012 at 10:39 PM
    08pretaco
    az
    Sorry for the attitude. It's just frustrating when your telling someone something and they argue with you about it :eek:
  13. May 17, 2012 at 10:45 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    :drool: :drool: :drool:
  14. May 17, 2012 at 10:53 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    I feel like this is sig worthy :D
  15. Jun 15, 2012 at 7:57 PM
    #35
    Miami X
    Miami X Member
    Don
    305, FL
    2012 BR X-Runner
    Short Shifter, TRD S/C, afe Stage II CAI
    So, tell us: How do you like the performance of the Airraid CAI? No CELs? Good sound? Performance boost? do tell!
  16. Jun 15, 2012 at 8:37 PM
    #36
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    This is just money wasted that could be put into something much better!
    Unless of course if you have a supercharger.
  17. Jun 15, 2012 at 9:19 PM
    #37
    Miami X
    Miami X Member
    Don
    305, FL
    2012 BR X-Runner
    I have a supercharger and a very restrictive 2012 intake design.
  18. Jun 15, 2012 at 10:20 PM
    #38
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Yeah it is. I had a stock intake on a TRD s/c and decided to put in a K&N CAI strictly for looks because I hated the look of that stupid factory box taking up half the engine bay and covering up my secksi s/c. I installed it and was stoked with how much better my engine bay looked but the real surprise came when I started the truck. It turned over much easier and idled much smoother. When I took it out of the garage the throttle response was instantly noticeable. When you start to press the gas peddle the engine instantly responds whereas before there was a slightly lag between the gas peddle press and the engine actually responding. Not so now. The next thing I noticed was how LOUD my s/c was under WOT. It screams and sounds amazing. I got mine used and am VERY happy that I decided to go with it because I wasn't expecting any performance gains what-so-ever based on all the threads I read on this forum. In my case it was noticeably better in just about every aspect.
  19. Jun 15, 2012 at 11:02 PM
    #39
    Ostrichsak
    Jer
    Sorry to burst your bubble but I never said I got more power out if mine. That would require extensive dyno testing both before & after to be able to state & I haven't gone to that much effort. I stand by all of my previous statements. Please don't put words into my mouth to try to make some sort of point.
  20. Jun 16, 2012 at 7:40 AM
    #40
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    You just opening your mouth gets everybodys panties in a twist.
Thread Status:
