Does my 99 SR5 3.4 5spd have an oil cooler?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AviateGW, Apr 25, 2015.
  1. Apr 25, 2015 at 10:18 AM
    AviateGW
    AviateGW [OP] Well-Known Member
    Glenn
    Atlanta area
    Black '99 3.4 SR5 4x4. OME/Dakar
    16x8 KONIG Countersteer Offroads from FN, OME/881s in front, OME shocks/Dakar leafs in back. K&N CAI, and last, but not least, TRD Shift knob.
    Soooo, I'm about to do a timing belt change.
    The ads for the kits I've seen online want to know if I have an oil cooler. I don't see what I would think of as an oil cooler anywhere in the vicinity of the radiator, much less anywhere else.
    Any advice on whether or not I have an oil cooler?
    Thanks in advance....
  2. Apr 25, 2015 at 11:06 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Pretty sure the answer is NO, unless a previous owner installed something aftermarket.
  3. Apr 25, 2015 at 11:18 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    ^^This^^
  4. Apr 25, 2015 at 11:47 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Most do, it's not the typical style. The only relevance pertaining to t-belt "kits" would be the water pump. The non oil cooler pumps do not have a nipple for "No. 2 Oil Cooler Hose". The nipple in question is located on the outboard driver side of the t-stat housing/water pump.
  5. Apr 25, 2015 at 2:02 PM
    Norton
    Interesting. I don't see those parts on mine or my son's engines. :confused:
    Where/how is the oil cooled?
  6. Apr 25, 2015 at 2:50 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Here is a water flow diagram. Oil flows in and out directly from the block just like an oil filter.
    When I said "most", that may have been some what presumptuous on my part. All the 5vz trucks that have suffered my intrusions have had it and I remember a similar discussion where most of the folks had it.
    The pic below while accurate, is clipped from a larger Toyota document pertaining to T100's.
    The note for *2 reads "Except 2wd with auto trans". I have no idea which tacos got it or not.
    Here's the oil flow diagram.
  7. Apr 25, 2015 at 5:10 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    I just did the timing belt/water pump in mine, an 2002 3.4L, and it does have a oil cooler. The diagrams Dirty Pool & Norton shared show the components. You can check for oil cooler on the car at two points:
    1. Lower radiator hose where it connects to thermostat housing and housing bolts to engine/waterpump. Right there on the back of the housing, in front of the thermostat, is a nipple protruding to the right (driver's side) of the truck. A rubber water hose connects to it and makes a dog leg following the engine (driver's side) back toward the firewall and the oil cooler on the back left side of the engine.
    2. The actual Oil Cooler is the other part you can physically check for. It is closer to the firewall and pretty much in a line with the oil filter location (so maybe a foot?? to the right of the oil filter). If you get under and just behind the drivers side wheel and look up at the engine you should see it.
    I am not sure if the pre-2001 3.4's had the oil cooler? When I look at my parts lists pdf's, it shows an oil cooler for 2001-2004, but I do not see that on the 1995-2000 parts list. Maybe others with the earlier 3.4's can weigh in.
  8. Apr 25, 2015 at 7:53 PM
    Norton
    Thanks for the education, guys! I'm going to look more closely, next time I drop the skid plate.
  9. Apr 26, 2015 at 6:36 AM
    AviateGW
    Glenn
    Atlanta area
    Thanks guys!!
    I was waaaay off. I mistakenly thought that an oil cooler would cool the oil by transferring the heat into the air via a radiator-like device. It looks to me like the heat is transferred to the engine coolant at a relatively 'cool' point in the system. I can see the oil line leading from the thermostat housing from the top of the engine, just below the alternator. This is a lot like a fuel-cooled oil cooler in a jet engine....
    I would not have believed this without the diagrams that Dirty Pool shared. Thanks man!
  10. Apr 26, 2015 at 9:08 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    My 99 has it. There is no mention of it in the entire 99 "Tacoma sales brochure" under "options" or "option packages". Nothing noted on the original build sheet.
    Gadget of URD once described the cooler as more of an (oil temp stabilizer) as it helps to warm cold oil quicker and keep it at a more uniform temp. He really liked it and felt there was no need for anything additional.
  11. Apr 26, 2015 at 9:50 AM
    Norton
    +1 to all of this. The oil cooler in my 2013 Shelby works exactly as you describe, transferring heat into the air via a small radiator, so that's what I looked for as well.
    There's nothing in any of the documentation for my truck either. Gadget's "stabilizer" description does seem more accurate than calling this setup a "cooler". Thanks, again, for the education.
  12. Apr 26, 2015 at 8:37 PM
    arifleman
    Pacific NW
    I did some online digging and Toyota's literature on their T100 5VZ-FE says,"The lubrication system of the 5VZ–FE engine is basically the same as that in the 3VZ–FE engine of the ’92 Camry. However, in order to lower the engine oil temperature on all models (except the 2WD model with automatic transmission), a water cooled oil cooler has been adopted."
    I would guess the same holds true for Tacomas, that, "all but 2wd model with automatic transmission" have the oil cooler.
    Regardless what we call it, it certainly is a slick way of providing for more consistent temperature control across the engine. No wonder these engines can routinely run a quarter million miles and more!
  13. Aug 19, 2015 at 12:22 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    I'm about to hit 200k and a helpful member showed me this link. Thought I'd add to it to share what I saw. Crawled under the truck just behind the front drivers side tire.
  14. Jan 24, 2024 at 6:49 PM
    Nissan-Nikki
    Nissan-Nikki New Member
    Tacoma 3.4l V6 Manual 4x4 TRD
    My 1999 4x4 Taco definately HAS one and we just ‍♀️ordered the kit without ... My old man is not happy right now. On the other hand, i would bet that this design is one of the many reasons that this truck is so reliable! Sucks, but it looks like we'll be reordering and redoing this water pump and timing belt replacement like it pr not... While we're there, this time, we'll replace all the pulleys, belts, tensioners on this round... That way he feels as if he is doing a new fix not redoing one. Lol. ‍♀️
