Does my Lift look off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fatmonk8, Apr 20, 2018.
  1. Apr 20, 2018 at 5:50 AM
    Fatmonk8
    Fatmonk8 [OP] Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Just installed my lift wih the Bilstiens 5100's, 884 Coils, and HS 3 AAL.
    When I look at the truck from the side it looks like the front is much lower then the rear. Does this look normal? Was thinking maybe I should go up in coils to raise the front a little.
    ChadsPride likes this.
  2. Apr 20, 2018 at 5:51 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    What’s your 5100s set on?
    Also it takes a bit for the AAL to settle down. Go haul something heavy or pull a trailer
    ChadsPride and Coot83 like this.
  3. Apr 20, 2018 at 5:52 AM
    dnaTRD
    dnaTRD Well-Known Member
    I think the 886 or 887 coils would raise the truck. +the 1/4" spacer on drive side.
  4. Apr 20, 2018 at 5:52 AM
    dnaTRD
    Assuming you're set at 0 on the billies
  5. Apr 20, 2018 at 5:53 AM
    Tylerh147
    Tylerh147 Well-Known Member
    Tyler
    Chattanooga, Tennessee
    2007 DCSB TRD OR 4x4
    5100s, 885s, Icon AAL
    It's all personal preference really.... if you like the way it is now, then leave it. Otherwise, i would suggest either removing a leaf from the rear or going up to 885s.
    Coot83 likes this.
  6. Apr 20, 2018 at 5:53 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    The front by nature from the factory tends to be lower than the rear. Doesn't help that the front can also sag over time, but I assume you got fresh suspension up front? I do agree the rear is taller, but its not an uncommon symptom for even lifted tacos to have a lower front. If you can adjust more, then I would try that for the front.
    RyanL, Fatmonk8[OP] and ChadsPride like this.
  7. Apr 20, 2018 at 5:54 AM
    Fatmonk8
    Paul
    Delco, PA
    They are set to 0
  8. Apr 20, 2018 at 5:55 AM
    Fatmonk8
    Paul
    Delco, PA
    Ok, I do currently have the 1/4" space installed
  9. Apr 20, 2018 at 5:56 AM
    Fatmonk8
    Paul
    Delco, PA
    That's what I was thinking, maybe step up the coils to 885 or 886
  10. Apr 20, 2018 at 5:58 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    That looks like a natural factory rake. It will allow you to load the rear without sag.
    Fatmonk8[OP] likes this.
  11. Apr 20, 2018 at 5:59 AM
    Yukon
    Yukon Well-Known Member
    2009 Magnetic Grey SR5
    Rake is a good thing if you intend to use your bed.
    hammertaco11 and Fatmonk8[OP] like this.
  12. Apr 20, 2018 at 5:59 AM
    P51DeP
    P51DeP Well-Known Member
    Christopher
    San Jose, California
    2008 Single Cab Tacoma 4x4 Super White
    Fog Light Install, BFGK02's, Bilstein 5100's, 4x4 Armor Rear Bumper, Front and Back Light Housings(Euro Black) Sound Deadening Cabin, Tint all around.
    I'd say leave it. The back will settle a bit and trucks should have a small amount of rake in my opinion. I think it looks tough and I rock a little rake as well with just about the same set up.
    lynyrd3 and Fatmonk8[OP] like this.
  13. Apr 20, 2018 at 6:02 AM
    Col_Macklin
    Col_Macklin Well-Known Member
    2013 Murdered Taco/ ACAB 4wd 2.7L
    Notch up the front end a little or maybe add spacers to the top. In my opinion and experience, don't move up to the 886s. They are really stiff and you won't like the rough ride. I had the 886s but pulled them out after a month or so and reinstalled the stock. Unless you are doing really heavy offroading and or extremely heavy loads I would go with something light. But if you really want the 886s I can sell you mine for super cheap.
  14. Apr 20, 2018 at 6:58 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    Did you remove the OEM overload leaf?
    I just put in the exact same setup, now sits perfectly level
  15. Apr 20, 2018 at 7:07 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I’d say just leave it for now and let everything settle. I personally like just a slight amount of rake to account for addition load weight. Could be worse and you could have your bro lean going on.
  16. Apr 20, 2018 at 7:11 AM
    badger
    badger Well-Known Member
    07 SR5
    Is your goal to BE cool or LOOK cool? Adding heavier front springs to get a certain look will adversely affect the ride and function of your truck. Removing leafs to get a certain look will adversely affect your ability to haul a load. Springs and shocks should be chosen for the intended use of the truck, not to achieve a look.
    A properly functioning truck should have rake to accommodate varying loads. Level is fine for a truck that isn't used, or a dedicated wheeler, but stay soft on everything for good articulation.
    The nose up look came from the offroad racing world, and is there to absorb hard landings from jumps. It has no place on a mall cruiser, work truck, or offroad truck, UNLESS,.....looks are your deal.
    BWilley likes this.
  17. Apr 20, 2018 at 7:54 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Nothing wrong with the way it is now,leave it alone.
    BWilley and Fatmonk8[QUOTED][OP] like this.
  18. Apr 20, 2018 at 8:48 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Agree with what everyone has said so far. It depends on how high you want to go in the front.
    884=2"
    885=2.5"
    887=3"
    886=2.5" w/200+ added weight.
    I went with the 887 so I had the max amount of lift. I didn't want to have rubbing issues, but I still had to loose the front mudflaps. I have rubbed a couple more times, but only when stuffing. I love the ride with the 887 and nitro 90021 though. You having the 5100 have options. You can go up a notch and see if you like it, but it is generally recommended that you stay at 0. You could add a top plate spacer, or get new coils. Good luck. If you haul anything and are not looking for a full 3". Let it settle and see how you feel.
  19. Apr 20, 2018 at 8:54 AM
    Fatmonk8
    Paul
    Delco, PA
    No I left it in
  20. Apr 20, 2018 at 10:19 AM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    your tires are too small....
