Does my roof rack look dumb?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dsds, Apr 5, 2008.
Roof Rack - keep or remove ?
  1. Keep
    125 vote(s)
    43.9%
  2. Remove
    160 vote(s)
    56.1%
  1. Apr 5, 2008 at 3:59 PM
    dsds
    dsds [OP] Well-Known Member
    Calgary AB
    2008 DC TRD Sport - Black Sand Pearl
    TacomaWorld sticker, DRL mod, running boards, roof rack, remote start / security alarm, marker/turn signal mod, map light with dome light mod, TRD seat covers, rear spring TSB
    Greetings fellow Tacoma followers!
    I've been debating whether to remove my roof rack. I've only used it once.
    Every time I look at it, I question how it looks... almost as if I've added burly eyebrows.
    What do you think? Do you think it detracts from the clean sleek look of the roof?
    Since ya'll the experts, I'll go with what the majority votes.
  2. Apr 5, 2008 at 4:02 PM
    tealm0nsta
    tealm0nsta Member
    Houston
    08 Prerunner
    it looks more like grab handles for people standing on the running boards. would look better to go w/ the bar type like the nissan.
  3. Apr 5, 2008 at 4:05 PM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    I think you should remove it and give it to me!!
    Actually, I think it looks fine, but if you don't use it and remove it, let me know I would be interested in it. I have an Access Cab and want to see if I can make it work because I need one.
    GA
  4. Apr 5, 2008 at 4:25 PM
    dbbd1
    dbbd1 Well-Known Member
    Nope, only fits the DC, so give it to me!
  5. Apr 5, 2008 at 5:07 PM
    dsds
    Calgary AB
    Hmmm.. the poll is exactly 50/50 right now.
    Are you saying to remove only one? :rolleyes:
  6. Apr 5, 2008 at 5:24 PM
    rick
    rick `
    yes, it looks dumb
  7. Apr 5, 2008 at 6:16 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    I think they look great.
  8. Apr 5, 2008 at 6:19 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    I actually added one to my truck. I needed a rack and went with the OEM. I think it looks good.
  9. Apr 5, 2008 at 6:20 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    I say remove it, only because the only roof racks I see around here are on Frontiers. You don't want to look like a Frontier do you? Hahaha. I say keep it if you really need it.
  10. Apr 5, 2008 at 6:38 PM
    tacowheels
    tacowheels Member
    I think the roof rack looks pretty good, but if you're not using it, I also would be interested in purchasing it from you.
    My only concern is the installation of them, as I think there are bolt receivers inserted into the roof for to bolt the rack to. This would mean that after removal, there may be holes in your roof which would need to be plugged.
    Please correct me if I'm wrong anyone!
  11. Apr 5, 2008 at 6:47 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I voted remove. If you are like me you were thinking about taking them off and just wanted to make sure others agreed. They will bug you if you keep them, or atleast would bug me but only because I have no use for them. Make sure it dosen't leave holes. The truck will look good just as long as you are happy with it.
  12. Apr 5, 2008 at 7:14 PM
    midget1958
    midget1958 New Member
    07 4x4 off road
    TRD seat covers, tube steps, Kenwood kdc-mp435u, Infinity 6x9 front, 6.5 rear speakers, sirius
    The truck looks great. I would loose the rack I think it just doesn't look right. If you like the look keep it.
  13. Apr 5, 2008 at 7:17 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Welcome to TW midget! I shall call him...mini-me.
  14. Apr 5, 2008 at 7:19 PM
    SteelCity
    Charleston, SC
    Yep, you would have holes to fill as there are bolts welded to the roof to accept the hardware. They had some kind of "foil" type seal over them. The other thing is you have to get is new channel rubber. It clips on a couple of spots in the front and rear of the channel. When the rack is installed, you actually break of the front clip tabs so it fits. Therefore, you have to come up with another way to hold that part down. Should be an easy fix though.
  15. Apr 5, 2008 at 7:50 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    i'd keep it on. wish i was able to put one on mine, then i'd make a light bar that goes across it. that would look sick, IMO
  16. Apr 5, 2008 at 8:09 PM
    TACOROCK
    TACOROCK Well-Known Member
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    URD SUPERCHARGER 80MM PULLEY, DOUG THORLEY LONG TUBE HEADERS, MODIFIED Y-PIPE, TRUE DUAL EXHAUST MAGNAFLOW 2 IN 2 OUT, PRO COMP 6" LIFT, WIDEBAND 02/FUEL SENSOR, AVIC D3, 2 PIONEER SUBS ON A MEMPHIS 1200 WATT AMP RMS, DIY MOD FOR ALL INTERIOR SPEAKERS FULL TINT, LEER CAMPER, EURO LIGHTS, BILLET GRILL, BULL BAR WESTIN RUNNING BARS, AIR HORN, AND A RADIATOR POPPER
    they would definately look stupid on my truck
  17. Apr 5, 2008 at 8:16 PM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    I am not a fan of the roof rack at all. The only reason why I would have those on mine is if I actually used them.
  18. Apr 5, 2008 at 9:23 PM
    rocivm
    rocivm miss south !! haha!!
    miami, fl
    05 radiant red x runner
    ..intek, halo ring proyector lights and fog, hid 8k, bed cover tuxedo, seat cover leather,black scoop hood, red line nitto tires, ...hehe and etc etc
    keep it, look better on the truck!!!!
  19. Apr 5, 2008 at 9:24 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    We prefer to be called "little people"...Thanks! :eek:
  20. Apr 5, 2008 at 10:26 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I voted take it off (that's what she said) only because of looks. If you use it, then keep it on there. I'd have one if I needed it. I'm all about function over form when it comes to my purchases.
