Does my roof rack look dumb?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dsds, Apr 5, 2008.
Roof Rack - keep or remove ?
  1. Keep
    125 vote(s)
    43.9%
  2. Remove
    160 vote(s)
    56.1%
  1. Apr 8, 2008 at 1:42 PM
    #41
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    For the holes, silicone should be fine, or just get another short bolt and stick it in place to plug the holes. As for the front clip, the rubber channel sort of snaps onto the clips. Since the clips are gone, you may be able to either use extra double sided tape up front (you also us it in the back even though the rubber slips under the window molding), or glue a small block of plastic (such as acrylic) to the channel for the trim to sit on.
  2. Apr 8, 2008 at 4:18 PM
    #42
    dsds
    dsds [OP] Well-Known Member
    Calgary AB
    2008 DC TRD Sport - Black Sand Pearl
    TacomaWorld sticker, DRL mod, running boards, roof rack, remote start / security alarm, marker/turn signal mod, map light with dome light mod, TRD seat covers, rear spring TSB
    Thanks steel dude. I'm going to tackle it tonight and just tape the front down until I buy something tomorrow.
  3. Apr 9, 2008 at 12:17 AM
    #43
    dsds
    Calgary AB
    So after passing a RR, SB, SSM, and 2 BSP, I finally got home and removed the roof rack.
    BTW, nobody waved back when I did a "lift the hand wave from the top of the steering wheel" type of wave. However, the last guy with a BSP truck did a "deer in the headlights" stare back at me.
    To continue:
    - rack came off easy and no scratches underneath
    - lots of dust and dirt got in underneath but nothing major
    - wiped channel clean and then filled the bolt holes and the surrounding area with silicone
    - started at the rear with glue on the foam tape strips to hold down the rubber at the bend
    - pushed the rubber down on the rear plastic clip
    - pushed the rubber down up to the front
    - used epoxy putty pressed around the notched plastic on the rubber channel, then pushed it down into epoxy where the front plastic clip should have been
    - used strong magnets to push down on the rubber to let the epoxy do its work
    The rubber went in easily.. almost too easily. I hope it keeps the water out.
    Maybe I should have used foam tape at the front. But everything was closed after work and I had to get it off tonight.
    I shall find out soon enough.
    Below are a few pics.
    No more metrosexual or Frontier fears for me!
    Cheers!
  4. Apr 9, 2008 at 12:24 AM
    #44
    dsds
    Calgary AB
    front of rack right side
    rack removed showing bracket for rack
    Plastic clip at rear. This one is broken off at front to install rack.
    All done! Using strong honkin magnets to push down rubber channel and some shiny silver duct tape:
    With Rack:
    Without Rack on pickup day with only a few miles. Back to what I like.
  5. Apr 9, 2008 at 6:39 AM
    #45
    gsxr3000
    gsxr3000 Well-Known Member
    08 TRD Sport
    OME Lift Kit, TRD S/C CAI EXHAUST
    changed my mind... looks better on.
  6. Apr 9, 2008 at 9:12 AM
    #46
    rmd0311
    rmd0311 Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    What can I say... DUMP IT.
  7. Apr 9, 2008 at 9:27 AM
    #47
    Flaadog
    Flaadog Well-Known Member
    Pacifica, CA
    2002 Double Cab TRD SR5 4x4
    Toytec 3" Pro Deluxe 1000 lift, Bedrug, Snugtop, Yakima rack, Goodyear Wrangler Silent Armor 265/75R16
    Yakima baby!
  8. Apr 9, 2008 at 10:46 AM
    #48
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    put a safari rack on it.
  9. Apr 9, 2008 at 11:00 AM
    #49
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    I voted to remove....It does make it look like a Frontier. [​IMG]
  10. Apr 9, 2008 at 5:03 PM
    #50
    dbbd1
    dbbd1 Well-Known Member
    So now, is it for sale???
  11. Apr 9, 2008 at 5:21 PM
    #51
    dsds
    Calgary AB
    YES. PM me and I'll find out if shipping charges are crazy from here to you.
  12. Apr 9, 2008 at 9:28 PM
    #52
    rocivm
    rocivm miss south !! haha!!
    miami, fl
    05 radiant red x runner
    ..intek, halo ring proyector lights and fog, hid 8k, bed cover tuxedo, seat cover leather,black scoop hood, red line nitto tires, ...hehe and etc etc
    so... why u asked for opinions if u gonna do what u think its better??? dont ask, do what u really like to do!! ...or put fire on it!!!! ( ups, bad idea)
  13. Apr 9, 2008 at 11:15 PM
    #53
    divetaco
    divetaco Member
    taco TRD 4x4 bare stock
    stock
    remove them! unless you're going to add a canopy, which ,might elongate the look..then keep em. So as is remove em
  14. Apr 10, 2008 at 6:17 PM
    #54
    Brett N
    Brett N New Member
    Madison Mississippi
    05 Prerruner Silver & Black
    17" Rims, Cooper Discover ST Tires, Black Nerf Bars, Black Low Profile Tool Box, Black Thule Roof Bars, Alpine Stereo, Infinity Speakers
    Keep the thing, and add an accessory to it. I had to get a Thule , because, Toyota does not offer the thing for a Access cab, believe it or not. I have bars going accross and added a goal post to my trailer hitch. When I have my canoe on top and out the back , it is cool as can be.
  15. Apr 30, 2008 at 8:26 PM
    #55
    fir$toyota
    fir$toyota Member
    Gypsyville, Florida
    2008 Tacoma Double Cab TRD
    way better. nice job.
  16. Apr 30, 2008 at 8:30 PM
    #56
    fir$toyota
    fir$toyota Member
    Gypsyville, Florida
    #56
  17. Apr 30, 2008 at 9:49 PM
    #57
    dsds
    Calgary AB
    Thanks for the link!
    Great price too.
    Oh, yeah, I didn't really think about expansion and contraction issues.
    Cruising along and the right side rubber channel popped off from the front and flipped over landing into the bed.
    Luckily the sticky tape at the rear held it from flying away.
    Anyways, now the front is fixed with epoxy and the rear slides in the original channel clip.
    I left out the epoxy at the back which screwed me up.
    Hasn't been a problem since.
  18. May 1, 2008 at 7:30 AM
    #58
    99TRD
    99TRD Well-Known Member
    17 Tacoma TRD OR DC Auto V6
    Smoke headlights, improved LED tail lights...Pending: De-chrome badges and grille, new tires
    I voted to remove. I guess my question is....If you have a truck bed, why in the world would you need a roof rack? You are hauling so much s%$t that you need the extra room? Maybe you need a Tundra.
    I also agree with an earlier post that it looks like a Nissan Frontier.
  19. May 1, 2008 at 7:39 AM
    #59
    99TRD
    Obviously, I posted before I read the entire thread. I think it looks great without. Nice job, hopefully it doesn't turn into a huge hassle.
  20. May 1, 2008 at 8:54 AM
    #60
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Looks better go with Yakima like myself.
