Does My Spare "need" to be the same size as my other tires?
Discussion in 'Wheels & Tires' started by Benny, Oct 7, 2010.
  1. Oct 7, 2010 at 6:30 PM
    Benny
    Benny [OP] Well-Known Member
    2008 DC LB more mods by the month
    I just ordered a set of tires, stepped up to 265/70-17. Only about one inch bigger than stock diameter. I don't really want to buy a full size spare and I don't think I need one. If I ever do have to run the mis-sized spare, I figure I will put it on the back and then not use 4WD. Does that sound like a bad idea?
  2. Oct 7, 2010 at 6:33 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Think about it, most spares are much smaller then a full size tire. I'd think if u don't driver very far you'd be fine. Just my 2 cents
  3. Oct 7, 2010 at 6:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    do you have a LSD? If so you need to match the sizes but otherwise you should be fine.
  4. Oct 7, 2010 at 6:40 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    This. If you have a mechanical LSD you need the right size spare. Running one the wrong size on the axle with the LSD will wear out your LSD clutches.
  5. Oct 7, 2010 at 6:45 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    If you're just limping home and have an open diff on whatever axle gets the spare, you'll be fine.
    Fullsize spare is nice due to preserving the ability to use 4wd, although technically you can do that with an offsize spare as well.
  6. Oct 7, 2010 at 9:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If you need it, put it on the *front* and then don't use 4wd. That'll keep your differential from working too hard.
