Does my spare need to match?
Discussion in 'Wheels & Tires' started by seoulja99, May 10, 2016.
  1. May 13, 2016 at 4:58 PM
    seoulja99
    seoulja99 [OP] Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    I agree with @digitaLbraVo...you're better off matching the size...not the brand or as close to a full-size as possible for a spare.
    The reason I say "as close to" a full-size spare is because you have seen those non-full-size spares for sedans. They are much smaller and thinner than the actual tires, and that is why they have large print saying not to drive for long periods of time and not to exceed 50 mph (or 80 kph). You'll be causing all sorts of damage if you keep it on for a long time and exceed the 50 mph limit.
    digitaLbraVo likes this.
  2. May 13, 2016 at 5:08 PM
    Onlydad
    Onlydad Well-Known Member
    2014 Tacoma
    Stock
    Well, here goes.. Assuming you don't do alot of wheeling (most don't) and assuming you own and can use a plug kit and assuming you own an MV50 or any small cheap compressor, you really have no need for a spare at all. Tubeless tires rarely go flat. Unless you're wheeling seriously you won't puncture a tire. If you are wheeling seriously you won't be alone and chances are someone with you will loan you a spare. If you do get a flat you can simply fill it up with your comressor and drive somewhere to get it fixed, or.. I've always carried a few plugs with me, I'm far too lazy to actually change a tire without my floorjack and air tools.. Don't waste money on a spare..
    Honestly, I don't know why people bother having a spare in this day and age. 40 years ago with tubed tires sure, but today's tires are exceptionally well made..
    Good luck..
    seoulja99[OP] likes this.
  3. May 14, 2016 at 7:47 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Man you make a lot of positive assumptions. I don't plan for the worst cause I know it won't happen. I plan for the worst cause when it decides to happen it is the worst.
  4. May 14, 2016 at 8:00 AM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    You could run a 255/85-16 on your stock spare wheel. That would match pretty closely with your 285/17s and not hang down too far under the truck.
  5. May 14, 2016 at 8:01 AM
    digitaLbraVo
    :thumbsup:
    This guy knows what's up.
  6. May 14, 2016 at 9:42 AM
    seoulja99
    E.J.
    Oahu
    But finding that size here Oahu is almost impossible. Most guys here have to special order that size.
    They do look awesome and function/perform well, though.
