Does my suspension plans make sense?
Discussion in 'Suspension' started by SAIRS, Apr 1, 2012.
  1. Apr 1, 2012 at 10:30 PM
    SAIRS
    SAIRS [OP] Well-Known Member
    Kelly
    Utah
    Super White 2012 Double Cab LB TRD SPORT
    Icon Extended Travel Stage 1, Total Chaos UCA's, Dakkar leaf pack, Beefed DCLB Sliders with extended kickout and custom BSP, Beefed Custom exo-rear tube bumper, Toyota bed mat, tailgate theft mod. Front mudflaps removed, Access LE soft tonneau cover, Weathertech digital floor mat, Weathertech window deflectors, Weathertech license plate frames. future plans = diamond plate tailgate mod, Venture Shield, TRD supercharger...the dream goes on and on....
    So I have a 2012 Tacoma Double Cab Long Bed Sport. I have ordered 18x9 XD Monsters and 285/65/18 Nitto Trail Grapplers. They will be here by the end of the week. I need to get my lift ordered.
    I was going to go with the Toytec Ultimate Lift kit, but they are back ordered on the rear shocks. they offered to give OME rear shocks, but I dont want silver/red coilovers up front and yellow shocks in the rear. Its stupid, but I dont want my 2012 to look like its wearing mis-matched socks. So I am planning on ordering a better suspension....
    I am planning on ordering the Icon Extended Travel Stage 1 kit that is on the toytec website....
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    Im also planning on putting on the Dakkar leaf springs, 7.5 inch u bolts, front diff drop, carrier bearing drop, axel shims.... I was planning on going the LR uca's but I spoke with DSM and they say the LR are more restrictive to the extended travel kit and I should be getting Total Chaos UCA's and get a stainless steel part (I believe its the uniball itself) since I live in Utah and have salt to deal with regularly in the winter.
    I am not planning on doing alot of crazy offroading. I just want the best suspension while I am single and can afford it. I'll do some dirt trails, but nothing nuts. this will see alot of city / highway driving and some trails. no top over the bed either. I want to do the upgrades right the first time.
    four questions then
    Do I really need to go with the TC UCA's over the LR UCA's to take advantage of the extended travel shocks in the front?
    Is the Dakkar leaf pack over kill?
    Am I going to need anthing else for this lift?
    This suspension should be bolt off the old and bolt on...is it more complicated then that?
  2. Apr 1, 2012 at 10:32 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2018DCSB TRD Quicksand
    Emu 887x Nitrochargers Dakar Heavys, 255 85 16 ST-MAXX
    the dakar leaf pack is not over kill. there is no such thing
    extened brake lines will be recomened by me.
    If toytec recommended you to do it, and the price range isnt that big, go for it.
  3. Apr 1, 2012 at 10:39 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    I have Icon stege II kit coming to me thursday. I have the ext. travel one's too but i'm going with with the LR uca's because it is not a big deal for light offroading.
  4. Apr 2, 2012 at 10:24 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Do you tow or haul alot? If not maybe you should look at the allpro standard leaf pack. I've had the dakars and they were great, but I now run the allpro's and they fit my needs better. Main difference would be the dakars overload springs can be a bit harsh if you wheel fast. Also, you probably wont need a front diff drop, and just pick either the CB drop or the shims. No need for both, but dont install it until you see if your truck gets a shutter..
  5. Apr 2, 2012 at 11:21 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Agreed
  6. Apr 2, 2012 at 11:44 AM
    SAIRS
    Kelly
    Utah
    Marcos at DSM just pointed that out with the diff drop. I guess with the dakkars you don't need the shims since they are apparently built in already. I'm not planning on offroading hard or towing. I help friends move every once in a while though. I just want to do it right the first time.
  7. Apr 2, 2012 at 12:01 PM
    OZ-T
    Peter North
    British Columbia
    The shims are not " built in " to the Dakars
  8. Apr 2, 2012 at 1:13 PM
    SAIRS
    Kelly
    Utah
    I guess I misunderstood him. He said the shims were not necessary, but the carrier bearing may be necessary. He also referred to the leaf springs as ARB's. Are the OME dakkars leafs the same as ARB?
  9. Apr 2, 2012 at 1:17 PM
    OZ-T
    Peter North
    British Columbia
    The OME Dakars are made by ARB , as is the rest of the OME stuff .
    Axle shims are used to correct your pinion angle after the installation of your lift , they may or may not be needed . Perhaps it is their experience that they are generally not needed .
  10. Apr 2, 2012 at 5:42 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    There's a dude here running the LR UCA's and Icon ext travel but for a little more you might as well do it right like you said! I agree that the All Pro standards will ride a lot smoother than the Dakars....they're great just built for hauling duty and not comfort/flex!
    You'll be happy with the Icon's, that's what I'm switching to as well!
  11. Apr 2, 2012 at 5:45 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    how did you call DSM but decided to purchase from toytec? always thought DSM had the best deals.... :confused:
  12. Apr 2, 2012 at 7:24 PM
    SAIRS
    Kelly
    Utah
    I am going through DSM now.
  13. Apr 2, 2012 at 7:29 PM
    SAIRS
    Kelly
    Utah
    Part of the problem with the TC UCA's is the uniball will rust / wear out I suppose within the next year or so since I live in SLC, Utah and have salt on the roads in the winter. TC is about to release some UCA's with stainless steel uniballs so that wont be an issue. It looks like I will just have to remove them when the go bad and replace them. the new uniballs wont be available for another month. unfortunately, I cant wait since I have to trade in my tires in a week or so, so I cant hold on.
  14. Apr 2, 2012 at 7:37 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    camburg's uniballs are stainless steel I think. you ask about those?
  15. Apr 2, 2012 at 7:41 PM
    SAIRS
    Kelly
    Utah
    I did not. Going TC was a recent decision anyways. I was going the LR route until I found they were restrictive for the Extended Travel shocks that I'm ordering. What is the price difference between the two?
  16. Apr 2, 2012 at 7:48 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    from DSM I think the burgs are slightly less...but same price really its like 20$ ?
  17. Apr 2, 2012 at 7:55 PM
    SAIRS
    Kelly
    Utah
  18. Apr 2, 2012 at 9:14 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
  19. Apr 2, 2012 at 10:50 PM
    SAIRS
    Kelly
    Utah
  20. Apr 3, 2012 at 10:32 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Its happening with all of them. I had asked the question too and there were a few members that rotated the entire spring just enough to allow the uca to land between the coils. Looks like that's the only way around it other than limit straps if you you don't plan on fully drooping it (jumps etc) you should be fine! Another option is to just get the regular non extended version and LR uca's will work fine with those. Your loosing about 7/8" of down travel and would be hardly noticeable!
