Does my TRD supercharger sound right?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chueflee, Aug 31, 2018.
  1. Aug 31, 2018 at 4:43 PM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    I had my TRD superchrger installed this week. When I start the truck, it sounds like its knocking at 1st. once it get going it sounds normal though. When I turn it off it sounds loud too.
    Is this normal?
  2. Aug 31, 2018 at 4:48 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
  3. Aug 31, 2018 at 4:49 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I don’t know how anyone can determine with the given information. Using premium fuel?
  4. Aug 31, 2018 at 4:50 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I mean, are you sure you're not just hearing the blower rattle? That's pretty normal.
    Murphinator likes this.
  5. Aug 31, 2018 at 4:50 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    is the noise coming from the supercharger? I am pretty sure this is normal. My Dad’s truck and my truck are supercharged and they both do it. I looked it up and it’s something about the balance being slightly off at low rpms.
    Stryker420 likes this.
  6. Aug 31, 2018 at 4:51 PM
    chueflee
    Chue
    i'm trying to post a video but i don't know how. I'm using premium fuel 93 octance. Could be the blower rattling.
  7. Aug 31, 2018 at 4:52 PM
    VolcomTacoma
    Jeff
    NorCal
    If it sounds like marbles in a dryer, that's just the blower.
  8. Aug 31, 2018 at 4:52 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Upload the video to youtube and post the link here. Most likely if the truck runs fine when driving you are probably hearing the blower rattle
  9. Aug 31, 2018 at 4:52 PM
    chueflee
    Chue
    noise is coming from trd supercharger. Does it right when i start it up. Goes away and run normal.
  10. Aug 31, 2018 at 4:53 PM
    chueflee
    Chue
    your right sounds like marbles in a dryer lol. I guess its normal. Freaked me out at 1st.
  11. Aug 31, 2018 at 4:54 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah everyone does it the first month or so when you're like "WHAT IS THAT SOUND I JUST GOT THIS THING". You get used to it. Welcome to the money pit.
  12. Aug 31, 2018 at 4:55 PM
    chueflee
    Chue
    Thanks for help everyone!
  13. Aug 31, 2018 at 4:59 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Stryker420 and jojotoo like this.
  14. Aug 31, 2018 at 5:03 PM
    chueflee
    Chue
  15. Aug 31, 2018 at 5:04 PM
    chueflee
    Chue
  16. Aug 31, 2018 at 7:30 PM
    Korbnek
    Korbnek Well-Known Member
    Central Florida
    2013 Red Tacoma DCLB
    If it bothers you take the SC off and send it to me, I will dispose of it properly for you...
    Stryker420 and SupraMan like this.
  17. Sep 16, 2018 at 3:22 PM
    chueflee
    Chue
    I figured out the problem for the louder noise a couple weeks ago. The mechanic that installed my TRD SC over torqued the crankshaft pulley to 270ft/lbs instead of 270 newton/meter. The crankshaft pulley was cracked and started leaking oil. He replaced the pulley. Sounds better now
    https://youtu.be/U0KSx_tCDIA
    reefnfeef likes this.
