Does premium gas extend life of 3.4L?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtframer, Mar 24, 2017.
  1. Mar 24, 2017 at 10:50 PM
    #41
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Water dripping out of the exhaust is condensation from the atmosphere that you live in, even happens in dry Colorado land when a humid front rolls through.
  2. Mar 24, 2017 at 11:00 PM
    #42
    Aught2TaCO
    Troy
    Wheat Ridge, CO
  3. Mar 25, 2017 at 12:58 AM
    #43
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    This is twice the cost of AVgas:eek:
  4. Mar 25, 2017 at 1:11 AM
    #44
    Rburdeaux
    Rburdeaux Well-Known Member
    2004 Double Cab Prerunner
    whats AV gas?
  5. Mar 25, 2017 at 1:41 AM
    #45
    RysiuM
    Rysiu
  6. Mar 25, 2017 at 1:53 AM
    #46
    Jon27
    Jon27 Well-Known Member
    Jon
    Salt Lake City, UT
    2015 Toyota Tacoma Off Road
    Shit on a black truck.
    Glad I found this thread! The higher octane a gas means the more compression it can take before igniting. Therefore higher compression engines (sports cars corvettes lambos all the other shit I cant afford) have to use higher octane gas so it does not pre-ignite and cause damage to the rod, piston or some other part of the cylinder @benrpd said it perfectly.
    Better mileage will be from ethanol free gasoline for sure. The content of ethanol between regular and premium arent that much different. Regular is blended from multiple lower octane components as premium is made from fewer components to maintain the octane rating.
    Getting gas from a gas station doesnt really matter it depends on how they clean their tanks. All fuel from different companies has to be the same minimum specification or higher to be sold.
    All the additives like invigorate from Arco or techron or shell's nitrogen enriched gas are all lubricity additives with their own slight little tweaks but still pretty much the same thing as the specifications are still ran pretty tight. For emissions taking sulfur out of the gasoline removed lubricating components for the engine. They then turned to adding lead which was very hazardous and now you have a very well marketed lubricity additive for the oil companies.
    Top tier gas isnt really effected by the refining process directly. To qualify to be a top tier brand a company out of texas sends a truck to load raw fuel (no additives or ethanol) then tests it to see if it meets a certain standard pass or fail. They show up randomly without notice so there is no preparing for it and if your company fails once then you can no longer get back into the top tier group or whatever you may call it.
    Well there is my 2 cents from a refinery/terminal operator :thumbsup:
    DustStorm4x4 likes this.
  7. Mar 25, 2017 at 6:07 AM
    #47
    Indy
    Indy Master of all I survey.
    I think learning about octane should be mandatory before you get your drivers license. To get max hp an engine with x compression needs y octane. If octane is less than y a modern engine will detune to preserve itself but going over y still not supertune and create more than max hp. It only goes 1 direction. Assuming youre not forced induction, youre not high compression, run no higher than required and you can go a step lower to save more. You're mpg and hp change will be negligible and you won't damage your engine but you'll save money.
    High octane doesn't contain more energy, its not "cleaner", its not better. If your engine doesnt need it, it's a waste of money. Take the extra $5 and mail. It to me. Your vehicle will perform the same and ill eat lunch. Kind of win win.
  8. Mar 25, 2017 at 6:19 AM
    #48
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    This question again.
    The N/A 3.4 is rated by Toyota engineers for 87 octane. There is no power or mpg advantage to anything over 87 octane on a good running engine.
    Using anything other then 87 in your truck is like stuffing dollar bills into your tank and burning them.
    Rburdeaux and TacomaJunkie8691 like this.
  9. Mar 25, 2017 at 7:19 AM
    #49
    tony2018
    tony2018 Well-Known Member
    Always techron.
  10. Mar 25, 2017 at 7:28 AM
    #50
    2GSPointers
    2GSPointers Not a well-known member
    Nick
    Bradford, PA
    In between
    Anything newer than 2001 is supposed to be able to run E15. Flex fuels can run higher ethanol blends. I personally run E15 in my truck and actually saw a slight increase in MPG.
    I also work at an ethanol plant, so I am a little biased haha. It's 88 octane and .10 cheaper per gallon where I live. I'm also not trying to sell the stuff. Just giving my personal experience with E15. :)
    DustStorm4x4[QUOTED] likes this.
  11. Mar 25, 2017 at 9:12 AM
    #51
    harper7
    harper7 Well-Known Member
    Gary
    Tulsa/Claremore OK
    00 Imperial Jade 4x4 TRD,01 TRD 5sp
    For the skeptics,LIKE ME, I use Regular ..... this is a good read on Toyota's engine management ,advanced ignition timing advantages,knock sensors, detonation and the POSSIBLE long term advantage of using higher octane fuel.
    http://www.lcool.org/technical/prado_high_octane_fuel.html
    "When high octane fuel is used, the likelihood of detonation is diminished and the engine management system can advance the ignition timing further than that with standard fuel. Resulting in higher efficiency, greater power and torque as well as reduced fuel consumption."
  12. Mar 25, 2017 at 9:59 AM
    #52
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    This truck runs like shit from factory. 9.6:1 is not low compression. Detonation does in fact damage the engine over time. In the very least I'd run middle grade fuel once ambient temps are above 80 F.
    If you love your truck enough to spend time on a forum dedicated to it you should be spendning the extra $$ for premium IMO.
  13. Mar 25, 2017 at 11:38 AM
    #53
    Rburdeaux
    you put e15 into your 1st gen tacoma??
  14. Mar 25, 2017 at 11:47 AM
    #54
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    My girlfriend's 3.4L had 450k miles on it, and she ran nothing but the cheapest gas she could find. Engine still running strong today. Your fuel type won't make a lick of difference. Save the money and use it for maintenance on other areas that will actually help.
    TacomaJunkie8691 likes this.
  15. Mar 25, 2017 at 12:25 PM
    #55
    2GSPointers
    Nick
    Bradford, PA
    In between
    No I have a third gen. I'm just saying that vehicles 2001 and newer are supposed to be able to run E15 without problems.
    Rburdeaux[QUOTED] likes this.
  16. Mar 25, 2017 at 12:43 PM
    #56
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Keyword is "supposed." Id never put E15 in our 1 Gens. :playball:
  17. Mar 25, 2017 at 1:36 PM
    #57
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    ...yes it is
    needs be 10:1 ratio or more to even be considered a high compression engine.
    DustStorm4x4 and cruiserguy like this.
  18. Mar 25, 2017 at 1:49 PM
    #58
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I guess this is like Religion if you believe something is so nothing will change your mind .
    I hear the higher octane is better sermon I just engage the selective hearing
    DustStorm4x4 and Jon27 like this.
  19. Mar 25, 2017 at 5:16 PM
    #59
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I guess over 10 is the hard cut-off for low to high compression engines then. Thanks for clearing that up! 9.9:1 perfectly safe on the cheapest gas you can find, got it.
  20. Mar 25, 2017 at 5:29 PM
    #60
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think regular oil changes are more detrimental to engine life than the type of gas used.
