Does removing the AC compressor increase horsepower?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, Jul 5, 2021.
  1. Jul 5, 2021 at 7:06 PM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    One less thing puling on the engine, so more energy?
  2. Jul 5, 2021 at 7:08 PM
    egb1776
    egb1776 Well-Known Member
    2017 Tacoma OR
    If the clutch is working properly then the compressor drag should not make a difference. I would say it’s not worth the hassle.
  3. Jul 5, 2021 at 7:21 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Ac definitely uses a small amount of the engine power when it’s running, don’t know how much. I doubt if HP ratings by Toyota are done wirh the AC on so it’s more a matter of you won’t lose the little HP with AC running if it’s off or not running. Just turn it off if you want.
    crackedmirror[OP] likes this.
  4. Jul 5, 2021 at 7:38 PM
    Bishop84
    Bishop84 Well-Known Member
    Short answer is no.
    If you are looking for clever ways to save power, delete the fan and put in an electric fan with controls.
  5. Jul 5, 2021 at 7:39 PM
    1997tacomav6
    Denver
    X2
  6. Jul 7, 2021 at 9:35 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Personally I wouldn't do this. The stock fan clutch pulls a ton of air and is a lot more reliable than an aftermarket electric fan setup. I would take Cooling system reliability over MAYBE a 1% power gain on a Tacoma.
    I guess what's the end goal here OP?
  7. Jul 7, 2021 at 9:41 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    remove the seats, you will see more gain
    crackedmirror[OP] and slander like this.
  8. Jul 7, 2021 at 9:46 AM
    Chickenfarmer
    Chickenfarmer Well-Known Member
    Greg
    21 OR MT, 85 PU, 99 PR
    My a/c wasn’t working in my 85 PU. I took off the belt and increased 2-3 MPG.
  9. Jul 7, 2021 at 9:47 AM
    Glamisman
    Glamisman Well-Known Member
    sounds like a 4 cyl owner... fwiw, there is usually an override at WOT to shut the AC compressor off.
  10. Jul 7, 2021 at 9:58 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I mean, technically speaking, yeah.
    Are you going to notice, or is that going to turn your truck into some tire burning monster? No.
    Having a functioning a/c and thereby not having my nuts drenched in sweat is WAY more important than some phantom .001 HP increase.
    The answer for more power you are looking for is a turbo, lol...
  11. Jul 7, 2021 at 6:28 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As long as you never need to open the Windows .
    The real Power Hogs are the Power Steering and Alternator get rid of them
    Acid Dip all the steel body parts to reduce weight just never lean against the truck
  12. Jul 7, 2021 at 7:38 PM
    egb1776
    2017 Tacoma OR
    That sounds like you had a compressor on its way out causing substantially more drag than a fully functioning unit would. When I relieved my Cherokee of DD duty I stripped the ac and mechanical fan clutch off in favor of dual electric fans. The largest fuel economy bump I saw was 1-2mpg driving in traffic and maybe 1mpg on the highway.
  13. Jul 7, 2021 at 8:46 PM
    Bishop84
    100%
    Although the other end I had a stuck clutch on my 89 4runner, sounded like a semi truck, the 3.0 did nooooot like that.
