does replacing battery effect maintenance light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mpoirier, Nov 21, 2011.
  1. Nov 21, 2011 at 5:56 PM
    mpoirier
    mpoirier [OP] Member
    Charlottesville, VA
    '08 tacoma trd off road
    rear tsb, 5100's at 1.75", weathertech floorliners, wet okole seat covers, 265/75 Goodyear wrangler authority
    Just put in a new battery at 70,000 miles. Does this effect my maintenance required light? hoping not, because i did not note the mileage at my last oil change. i just reset the light and wait till it comes on again to change the oil. did changing the battery reset this though?
  2. Nov 21, 2011 at 5:57 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    NO
  3. Nov 21, 2011 at 6:08 PM
    mpoirier
    Charlottesville, VA
    great. thanks for the quick replies.
  4. Nov 21, 2011 at 6:12 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    well it might. My light was on and i welded something on my truck so i took the battery loose. when i reconnected light was out... :notsure:
    i change my oil every 5000 on the dot so it works out. Maybe do that to your truck go a little over next change and start maintenance every 5k so you dont have to rely on a light...
  5. Nov 21, 2011 at 6:52 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Didn't affect mine. Never thought about it until reading this. I replaced my battery a few weeks ago. It did reset something that I had to re-silence the seat belt chime and redo all my radio presets but my maintenance required light came on like always. Started flashing 500 miles out. That was just a few days ago. I'd imagine that since it's tied to the ODO it'll always work since disconnecting the battery doesn't zero the mileage.
