Does stock stereo have rca jackets in the back?
Discussion in 'Audio & Video' started by tacomanagger, Nov 22, 2009.
  1. Nov 22, 2009 at 8:00 PM
    tacomanagger
    tacomanagger [OP] New Member
    looking to put in amp and subs into truck. need to noe if im gonna have to put in a new deck or if i can keep it stock
  2. Nov 22, 2009 at 8:01 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    It does not come with RCA jacks.
  3. Nov 23, 2009 at 9:15 AM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    negative, you'll need a new HU.
  4. Nov 23, 2009 at 9:43 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  5. Nov 23, 2009 at 9:50 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    You can run an amplifier on any head unit that does not come with RCA outputs.
    Add-on amps required a low-level input, which the amplifier then boosts the signal and puts the power to your speakers.
    Speaker outputs from your radio (wires that plug directly into your speakers from the back of the radio) are line-level and power the speakers directly. This is because the radio already has a build in amplifier.
    You can't send line-level outputs from your radio into your amplifier. You'd kill your amp.
    What you need is a line-level converter that takes your speaker wires down to a low-level input and has RCA jacks on it. Then you can run them to your amp. They are relatively inexpensive.
    I have seen some older amplifiers that have an speaker wire input into them, and does it's low-level conversions within the amp. Not sure if that's common now a days.
    Converting speaker wires to low-level amp inputs are ok, but I've never heard such a setup that sounded better than an aftermarket radio with proper amplifier outputs.
  6. Nov 23, 2009 at 12:10 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Good: Line Output Converter.
    Better: Signal Processor like JL Audio CleanSweep or Rockford Fostgate 3 Sixty.2.
    Best: Aftermarket headunit with a high output volt.
  7. Nov 23, 2009 at 12:48 PM
    DaytonLax14
    Corey
    Ohio
    You'll be glad in the long run if you buy a new HU.
