Does Tacoma 2nd gen 2012 4-cyl/2.7 have a speed governor?
Discussion in '4 Cylinder' started by Tacoma2012/2.7L, Aug 10, 2020.
  1. Aug 10, 2020 at 9:43 PM
    Tacoma2012/2.7L
    Tacoma2012/2.7L [OP] Member
    Tacoma 2012 4l 2.7
    Hello everyone,
    Since this is my first post, I am doing a bit of an introduction of my Tacoma. I recently bought a used 2012 4-cyl Tacoma with just 100.000 miles on it. The previous owner bought it brand new back from the dealer, so this makes me the second owner. I have been with this truck for about 2 months, but I have done a full car tune up with quality spark plugs and KN air filter etc, but I am concerned with the following issue:
    Does my Tacoma 2nd gen 2012 4cyl 2.7 have a speed governor at 80/85 miles per hour?
    The reason why I am asking is because this is the second time that I have been on a long distance drive and my truck loses power when I pushed it to 5 out of 7 RPMX1000s (The 5 is not on the red (warning) mark). This happens when changing to the fast lane. When I accelerate and push the engine, the truck loses all its acceleration. Therefore, I need to move over to the emergency lane, stop completely and the engine starts shaking, until I turn it off. Once I turn it back on, the truck works just as fine as before, but the check engine light stayed on.
    The first time it happened, the code read was P506 and my mechanic took care of it, but he said possibly P0302 (Cylinder 2 Misfire Detected ) and P0303 (Cylinder 3 Misfire Detected) could be an issue too.
    Is it safe to say that these codes are the cause of the power lost or does my tacoma have a speed governor? I am just wondering if my tacoma does have a speed governor at all? If it the misfiring is causing it would this be expensive to take care of?
    Thank you guys for the help!
  2. Aug 10, 2020 at 9:46 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Aug 10, 2020 at 9:48 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes the misfires are the source of your power loss more than likely. What spark plugs did you use when you replaced the old ones?
    Speed governor is at 105 on my truck
    BillsSR5 likes this.
  4. Aug 11, 2020 at 5:23 AM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    DGXR and BillsSR5 like this.
  5. Aug 11, 2020 at 7:32 AM
    BillsSR5
    bill
    2014 SR5
    the original IRIDIUM plugs spec'd for a 2012 2.7l is 120k miles
  6. Aug 11, 2020 at 7:37 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    mis fire would be the coils not the plugs. assuming the plugs are new and the right ones.
  7. Aug 11, 2020 at 7:48 AM
    BillsSR5
    bill
    2014 SR5
    I sense non OEM Rec'd spark plugs being used with mis firing
  8. Aug 11, 2020 at 7:54 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I second the oiled air filters. I had a KN and it messed up my mass airflow sensor and allowed an excessive amount of dirt into my engine to which i had to take to Toyota to pump with special machine to the tune of $700.
    I now use OEM paper filters and OEM spark plugs.
  9. Aug 11, 2020 at 7:56 AM
    BillsSR5
    bill
    2014 SR5
    OEM parts are just better ive found out the hard way thinking im saving a few bucks but in the long run spending more to fix issues that occurred using cheaper aftermarket knockoffs
  10. Aug 11, 2020 at 11:45 AM
    Tacoma2012/2.7L
    Tacoma 2012 4l 2.7
    First of all, I want to thank you for the quick responses.
    The first time I felt the truck losing power, I had not done the tune-up yet. Therefore, it had OEM parts (denso Spark plugs etc) and that's when I got the codes originally. But even after the tune up with the Nk air filter, mobile one oil and filter, and NGK Laser Iridium 4094 spark plugs, the same issue happened. Which makes me think nor the spark plug or the air/oil filter have anything to do with it, right?
  11. Aug 11, 2020 at 11:47 AM
    adamr94
    Adam
    NC
    06 Regular Cab 4x4
    If replacing the plugs didn't do anything to correct your misfire, my money is on the coil pack.
  12. Aug 11, 2020 at 4:00 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    My 2.7 2008 loses power at around 100 MPH
  13. Aug 11, 2020 at 6:50 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Sounds like you've got a coil pack on its way out.
    whatstcp likes this.
  14. Aug 12, 2020 at 6:24 AM
    george3
    New Jersey
    Well if U R talking 2 me "My 2.7 2008 loses power at around 100 MPH" do U know how do I check that ? Thanks.
  15. Aug 12, 2020 at 10:52 AM
    Silverbullet8
    Silverbullet8 Active Member
    Upstate New York
    2012 2.7 5spd 4wd regular cab
    2 inch lift+285 tires custom catback exhaust Volant CAI PRO-M Tune
    Yes the 2.7 does Have a speed governor. I have a 2012 and it cuts out at 105.
  16. Aug 12, 2020 at 12:37 PM
    george3
    New Jersey
    Just as I thought - thanks for confirmation.
  17. Aug 12, 2020 at 10:52 PM
    Tacoma2012/2.7L
    Tacoma 2012 4l 2.7
    I have never hit a governor in any car. I am curious to know how that looks like?
    Well, it still seems that mine shouldn't have any problems at 85 miles per hour. So that is probably due to the misfires. I bought online a code reader to see if I get them same codes as before or what happened this time. I'll keep you guys posted once I get the new codes.
  18. Aug 14, 2020 at 7:55 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    There was a catalytic converter recall TSB on some of the trucks (my 2013 had it done by the dealer) so you might want to check and see if that applies to your truck and see if it was done. It could be a converter problem leading to the misfires after a high rpm blast.
  19. Aug 14, 2020 at 9:39 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the 2.7 engine will only go so fast / most engines can be computer limited
    the new 3rd gen 2019 IS speed limited in reverse
    if Ur 2.7 is throwing codes
    its entirely possible the ECU is retarding the ignition a direct result to ' MISfires '
    ' MISfires ' typically happen when load/speed exceed proper cylinder firing
    the ECU will pull back ignition timing to avoid engine damage
    proper installation of spark plugs
    good gas.........octane not the only factor
    adequate & consistent compression
    all are factors to consider
    good luck
  20. Aug 14, 2020 at 1:34 PM
    Tacoma2012/2.7L
    Tacoma 2012 4l 2.7
    Update:
    During the first tune up, my mechanic had actually swapped the coils (1-2, 3-4) when he put the new spark plugs. And told me to watch out for misfires 2 and 3.
    After doing the new code reading test, I only got code P0303 for misfire 3.
    Which now would be only left to a compression check?
