Does Tacoma 2nd gen 2012 4-cyl/2.7 have a speed governor?
Discussion in '4 Cylinder' started by Tacoma2012/2.7L, Aug 10, 2020.
  1. Aug 17, 2020 at 7:50 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ................????????? a special machine that will pump
    please explain
    any detritus inhaled into the engine will get blown out or remain to an extent
    if it Is apparent the intake needs cleaning usually requires inspection & reasonable disassembly
    to clean parts thoroughly
    please name that ' machine pump ' and its function
    sounds like its better than my girlfriend
    69 Jim likes this.
  2. Aug 17, 2020 at 7:58 PM
    ROAD DOG
    FEW
    if by some chance ( Not Ur fault ) conditions add up to ' pinging .....detonation ' (actually 2 very diff scenarios )
    the ECU will retard spark ignition several degrees to avoid engine damage
    wide open throttle......acceleration or better than the average load on the engine
    will damage valves or lower end bearings
    actual microphones are used to detect pings or detonation ( improper firing
    the ECU is program to pull back 2-4 degrees of ignition until the pinging or detonations stop!
    stale deficient octane gas or load grade + weight can be factors
    double check Ur tune up
  3. Oct 21, 2020 at 9:56 PM
    Tacoma2012/2.7L
    Tacoma2012/2.7L [OP] Member
    Tacoma 2012 4l 2.7
    Guys, just closing up this thread.
    I followed all of your advices: checked all cylinders' compression, coils were working fine, no gas-leaks, even added a new battery.
    Well, it turns out that the issue was among the ECU and some defected wiring. There was a wiring soaking up extra energy and therefore draining batteries way too quickly (the battery was indeed damage, so I replaced before), damaging the ECU and being the source of the random misfires. My other mechanic feels that this was the reason why they sold the tacoma in the first place because he found a junk-yard fuse box (it was marked).
    He proceeded to reprograming and re-flashing the computer and the truck is working very well now. I repeatedly hit the speed where I was having the power issues. I have also run the truck about 500-700 miles and so far it is working great. It even feels much lighter and with more power.
    Thanks for your help.
    BassAckwards, DGXR and EdgemanVA like this.
  4. Oct 22, 2020 at 6:54 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Nov 3, 2020 at 6:18 AM
    biker666
    biker666 DisMember
    Oz
    Emerald City
    2007 5lug 2.7 AC 5MT RWD
    LED head, cabin and reverse lamps
    I want more information about the $700 cleaning done by the dealer
  6. Nov 4, 2020 at 10:05 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Great news, maybe not about the previous owner's choices but you got a good running truck now. Enjoy.
  7. Nov 4, 2020 at 10:16 AM
    81shark
    81shark Well-Known Member
    you hit it... and it shuts down the gas. you slow down a bit, gas kicks back in. it's not all that exciting
  8. Nov 4, 2020 at 10:19 AM
    81shark
    huh.. must of reduced it? i thought it was like 115ish on the earlier ones.
    BassAckwards[QUOTED] likes this.
  9. Nov 4, 2020 at 10:21 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Not sure on this. on my 09 4 banger its 105. on my 13 v6 its 110
    Seems as though they've chosen at random lol
  10. Nov 9, 2020 at 2:17 PM
    DGXR
    Friend
    Sacramento, CA
    Some governor systems cut the ignition but I believe most are designed to cut fuel.
    If an engine has no governor, then the max RPM is decided by valve float or some other system "malfunction" lol.
  11. Nov 24, 2020 at 9:03 PM
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    If I remember correctly, the Japanese translation of “speed governor” is
    “Tew-Tí-Ahr”.
    That could have something to do with it.
  12. Nov 30, 2020 at 5:44 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    My '15 is about 112. But at that speed you cant tell its being cut off cause its not really accelerating.
