Does the 2" leveling kit STILL cause the vibration in the newer 3rd Gens?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SteelerJim, Jun 15, 2022.
  1. Jun 16, 2022 at 6:16 PM
    #41
    wb_doublecab
    wb_doublecab Well-Known Member
    2020 ORLB
    I just got a 2020 and want to do new coils vs spacers I had in my '11. I don't want any rake. Want level or slightly higher in front. Do I need 5100 or something else? And the big question, will this screw up my front camera? Thanks in advance
  2. Jun 16, 2022 at 6:36 PM
    #42
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    You can alway adjust the front cameras. Robmotive did it it his front camera , something about adding washers to the tilt.
  3. Jun 16, 2022 at 8:04 PM
    #43
    KR75
    KR75 Member
    2021 Silver Tacoma TRD OR DCSB
    Would installing a diff drop reduce the vibration or the chances of it? Seems that would be easier and less expensive than doing the bushing.
  4. Jun 16, 2022 at 8:44 PM
    #44
    Lava-road
    2019 trd-off road
    After reading a few articles on benefits of the Front diff drop kit. It just reduce the CV angles back closer to factory specification. Prolonging the life of the CV axles and boots.
    No where is mention it reduces vibrations. Or help with “bushing” problems. Not related.
    East Coast Gear Supply , mention to stop the vibrations is replace with a clam shell bushings.
  5. Jun 16, 2022 at 9:05 PM
    #45
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Wouldn't getting the cv angles back closer to factory spec put less strain on the bearings? :confused:
    Junkhead likes this.
  6. Jun 16, 2022 at 9:57 PM
    #46
    Lava-road
    2019 trd-off road
    I wish I could answer your question. All I found was the lift puts a load on the right side (driver side ) bushing . The left side is built differently. When replacing the bushing it will be only the driver side.
    The drop diff kit, Has nothing to do about the loads on the driver side from what I understand. If not everyone would do a diff drop.
    I think calling East Coast Gear Supply could give you the best answers. There web site kinda goes into some of the details.
    What causes the actual loads? After a lift? Maybe there is some one who can explain this?
  7. Jun 17, 2022 at 7:36 AM
    #47
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I did the spacers shortly after getting my truck new so did not notice any change in ride quality over factory. But the 5100's are a 100X better than the OE suspension.
  8. Jun 17, 2022 at 8:49 AM
    #48
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Everyone does not get the vibration you're inquiring about.
    I have a 3rd gen with 2" lift, carrier drop kit and no vibes.
    ECGS bushing is recommended but not required and not required when you first do your lift.
    Be sure to source your answers. There's a very frequent phenomenon that happens on this site where 2nd gen truck owners exaggerate 3rd gen problems.
  9. Jun 17, 2022 at 11:15 AM
    #49
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    How does Toyota address this issue with the TRD lift kit and the trail edition with the factory lift?
  10. Jun 17, 2022 at 11:35 AM
    #50
    johnarebalo
    johnarebalo Well-Known Member
    Oklahoma City, OK
    2019 MGM DCSB SR5 and 1996 Desert Dune T4R Limited
    Tacoma - not enough T4R - too much
    Very carefully
  11. Jun 17, 2022 at 11:38 AM
    #51
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    AFAIK, they don’t and this is more evidence that there is no issue (at least you if you don’t go beyond 2”).
    Gen3TacomaOBX and Junkhead like this.
  12. Jun 17, 2022 at 11:39 AM
    #52
    Gen3TacomaOBX
    S
    They don't. I imagine if and when a bushing fails they're replace it with the factory part at their expense if inside the warranty period (at owners expense if outside the warranty period.)
  13. Jun 17, 2022 at 12:55 PM
    #53
    Lava-road
    2019 trd-off road
    It seems the clam shell bushing maybe a better bushing then the factory ones. Even under warranty might be wiser to spent the money on the clam shell bushing in the long run?
    Any lift may void the warranty?
  14. Jun 17, 2022 at 1:09 PM
    #54
    Gen3TacomaOBX
    S
    Debunked.
  15. Jun 17, 2022 at 1:15 PM
    #55
    TheTacoGarageServiceRep
    TheTacoGarageServiceRep Well-Known Member
    Andy
    2019 TRD OR
    After having installed many lifts we've only had one person request the needle bearing to be replaced but have not had any issues with vibrations after lifting.
    CROM123 and DRob like this.
  16. Jun 17, 2022 at 1:27 PM
    #56
    Lava-road
    2019 trd-off road
    Good to know .Thank you.
  17. Jun 17, 2022 at 3:32 PM
    #57
    OffroadToy
    Before being sold the new trucks at my dealership that they lift get the drivers side needle bearing replaced with the ecgs bushing. They know there's a problem.
    CROM123 and johnarebalo like this.
  18. Jun 17, 2022 at 5:11 PM
    #58
    Gen3TacomaOBX
    S
    What dealership is that? I can pretty much guarantee your dealership is an outlier. They must have an owner or manager that's an enthusiast.
  19. Jun 17, 2022 at 7:17 PM
    #59
    Ziggy16
    Ziggy16 Active Member
    22 off road
    Their are probably 1,600,000 Tacomas with lifts. Mine included. All are problem free. The 76 posted responses on here are the other half. …just saying
    CROM123 likes this.
  20. Jun 18, 2022 at 6:17 AM
    #60
    OffroadToy
    Well, at least that's what they told me when i inquired about getting the ecgs bushing installed... said they install many of them. The manager mentioned they had needle bearing issues with some of the lifted trucks they sold in the past and as long as they got it torn apart they go ahead and install the bushing.... less customer complaints. Their parts dept stocks them.
