Does the 4G Have a Cable Shifter?
Discussion in '4th Gen. Tacomas (2024+)' started by MJB4450, Feb 6, 2025.
  1. Feb 6, 2025 at 12:59 PM
    MJB4450
    MJB4450 [OP] Well-Known Member
    2025 SR5 Supersonic Red
    I watched a review video and the reviewer stated that the 4th gen auto trans has a cable shifter not an electronic shifter so that with no power the trans can be shifted to neutral. Is this true?
  2. Feb 6, 2025 at 1:24 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yes, there's a little plastic piece beside the shifter that can be popped out and be manually shifted in neutral in case of total power failure. Can't remember what you do once that little cover is removed, but it's there.
    batacoma likes this.
  3. Feb 6, 2025 at 1:29 PM
    MJB4450
    Yes? So you're saying yes it has a cable shifter but then you say it has a trans disconnect lever. It can't have both. It either has a traditional cable shifter so you can move the shifter to neutral without power or it has an electronic shifter and a hidden disconnector for when you have no power.
  4. Feb 6, 2025 at 1:35 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It can have a cable with this feature. All it does it undo the shift interlock without turning on the truck.
    MJB4450[QUOTED][OP] likes this.
  5. Feb 6, 2025 at 1:36 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I think it's a cable shifter like Delta09 says there is a shift lock release, and it sounds like it functions like all previous Tacomas.
    MJB4450[QUOTED][OP] and Delta09 like this.
  6. Feb 6, 2025 at 1:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Looks to still be cable operated.
    Even on transmissions with an electronic shifter every one I have seen has a manual park release somewhere either on the transmission or inside via a lever or cable to allow the vehicle to be rolled in the event of a failure.
  7. Feb 6, 2025 at 1:39 PM
    MJB4450
    OK, now I get it. Thanks. So not electronic but just has a switch to override the brake lock.
    Delta09[QUOTED] likes this.
  8. Feb 6, 2025 at 1:41 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea, luckily Toyota still does this. On some modern GM's there's no way to try and get the transmission in neutral (electronic) which sucks because fuel pump control modules on those is a wear item o_O
  9. Feb 6, 2025 at 1:42 PM
    MJB4450
    Yes that I knew. Both my Challenger and Grand Cherokee have a lever to pull up to disconnect the trans if you needed to get towed. Having a cable actuated trans rather than electronic is just another plus for the Tacoma in my quandary of whether to get another GC or the Tacoma.
  10. Feb 6, 2025 at 1:43 PM
    batacoma
    batacoma Truck Wars
    The electronic parking brake would still need to be disengaged if you were trying to move the truck after getting it in to neutral.
    Delta09 likes this.
  11. Feb 6, 2025 at 1:47 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Aaaand here you go raining our parade. :laugh: I honestly didn't think about it.
    Any tow truck operator worth their salt can get around this easy if flatbedded though.
    batacoma[QUOTED] likes this.
  12. Feb 6, 2025 at 1:54 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Yeah towing a vehicle with the parking brake on is a regular occurrence and not a issue at all.
  13. Feb 6, 2025 at 1:57 PM
    batacoma
    batacoma Truck Wars
    Yeah no problem for a tow truck operator. I like that Toyota used the shifter they used and the the electric parking brake is industry standard like most new vehicles and the components used.
