Does the Center Console USB ports also act as inputs to the Stereo?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Albertaktm, Sep 9, 2020.
  1. Sep 10, 2020 at 8:05 AM
    Albertaktm
    Albertaktm [OP] Active Member
    Alberta Beach
    2020 TRD Sport
    That's what i'm thinking. Get in behind where the usb plug pushes out through the dash. pull the plug back and plug in the iphone. Then i'll just have to figure something out for where the plug was. Like a knock a tiny out plate. I don't pick up the new truck till tomorrow so i'll hunt around then.
  2. Sep 10, 2020 at 8:23 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    they have blanks that will pop right in that spot
  3. Sep 10, 2020 at 8:43 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Be sure to format the usb drive to fat32 so mp3s will be rocognized. Also, if you're on Windows 10 use the app below to format, it's easier than the comand prompt.
    https://fat32format.en.lo4d.com/windows
  4. Sep 10, 2020 at 9:11 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Oh and one thing. Switches pop out the front. You squeeze from the back to release them. Then unplug the connector. Then pull the wire back into the dash. Then you can reconnect the switch inside the dash. To do all this you typically first remove the climate control plate. Which can be pulled once you remove one piece of trim near the steering wheel. Lots of YouTube videos to show this. Super easy.
  5. Sep 10, 2020 at 9:14 AM
    kadamik
    kadamik Active Member
    The Cplayair adaptor has to be plugged directly into the usb of the headunit, it will not work via a hub.
    I have done a setup similar to this one.
    https://www.tacomaworld.com/threads/2020-carplay-music-mod.682528/#post-24056927
    let me know if you have any questions?
  6. Sep 10, 2020 at 4:07 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If done right, there appears to be no limitations on the number of songs. 512GB and 54,860 songs.
    https://www.tacomaworld.com/threads/music-storage.310098/#post-7976419
    [​IMG] [​IMG]
    wahoobie and Grossomotto like this.
  7. Sep 10, 2020 at 9:18 PM
    Londo-Cat
    Londo-Cat Well-Known Member
    Guy
    2020 SR5 4x4 v6 w/predator package & midnight black metallic
    TRD Skidplates (Front/Back) Predator XP package
