Does the high mileage oil really help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 005Tacoma, Apr 19, 2011.
  1. Apr 19, 2011 at 2:52 PM
    005Tacoma
    005Tacoma [OP] Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    Does the 75,000 miles and up oil really help or is it another way to get more money from people.
    Is it really worth the $60+ bucks?
  2. Apr 19, 2011 at 2:57 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Best oil info. on the web --> http://www.bobistheoilguy.com/cms/
    Disclaimer: ... (except for --> chris4x4's "oil filter dissection study") ... :D
  3. Apr 19, 2011 at 3:27 PM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    The 5 gallon jug is ~$30 and the TOYO filter $5, where do you get $60
  4. Apr 19, 2011 at 5:35 PM
    005Tacoma
    2005 Toyota Tacoma
    From the place I have my oil changed
  5. Apr 19, 2011 at 5:39 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    help with what?
    I've read it has a chemical that swells seals to prevent or reduce leaks
  6. Apr 19, 2011 at 6:10 PM
    005Tacoma
    2005 Toyota Tacoma
    Help protect the motor. Basically what does high mileage oil do that the regular oil don't.
  7. Apr 19, 2011 at 9:07 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I've always used standard mobil1 synthetic, and my motors have always lasted well into the 100s of k miles. I wouldnt spend the extra dough unless its on sale for less than regular M1 Syn.
  8. Apr 20, 2011 at 4:36 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I think that additive to help swell seals is the only thing they have different that you might possibly notice an effect from. I suppose they could re-balance the additive package - to deal with increased blow-by from worn rings for instance - and that might help provide better protection. Other than that the base oils are doubtless the same as the regular oils and lubricates the same.
  9. Apr 20, 2011 at 4:38 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    If you're having your oil changed by somebody else, you're getting ripped off. Getting full synthetic from a place that changes oil probably isn't much less than the high-mileage stuff anyway.
  10. Apr 20, 2011 at 5:25 AM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    It is difficult for people without garages or strict landlords to perform oil change.
    Use Mobil 1 and follow your owner manual's OCI and you will be good.
  11. Apr 20, 2011 at 5:29 AM
    TacoSport
    NE
    An oil change is a 15 minute job, probably less if they don't let it drain fully, so $25-30 for service sounds high to me. Last time I checked, WallyWorld service will do a synthetic oil and filter change for less than $50.
  12. Apr 20, 2011 at 6:52 AM
    harleyg
    harleyg Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
    I have a 1995 Camry with 308,000 miles on it. I used to get a lot of oil leakage. Around 150k, I started using high mileage oil. It took about 2 oil changes, but the leaks disappeared. I can go 6k between oil changes (lots of highway miles) and not have to add a drop of oil. Before the high mileage oil, I had to add oil all the time. The stuff works.
    My local Meinke shop charges a few extra bucks for the high mileage stuff. I used to do it myself, but for what they charge, it is worth it.
  13. Apr 20, 2011 at 8:22 AM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I will grab 4 jugs at a time of the castrol high mileage for my wife's car when it's on sale, otherwise it just gets the regular stuff. It's a '03 Cavalier, 157k miles. Does it help or not, I don't know? I do know it doesn't cost any extra when it's on sale and the engine is in good shape, on the last oil change it had it's first leak and that was some weeping out of the axle seal in the trans, not engine oil. I still always get close enough to 4L of oil draining out that I've never even bothered to check the oil between changes.
    As far as paying for oil changes, that sucks, it's not a difficult job but I can appreciate what it means to not have a place to do it. If you have a car guy friend with a place to work on stuff it would be worth doing yourself. It's rewarding and it gives you the opportunity to get in there and inspect the engine & underbody and hopefully find problems while they're still a maintenance issue and not a break-down. Good chance to hang out with a buddy and talk trucks/cars too. If not though, while it sucks to pay too much it's more important that it's done competently. It's a simple job but when done carelessly very bad things can happen to your engine.
  14. Apr 20, 2011 at 8:24 AM
    mws4ua
    Birmingham
    I wasn't criticizing for not performing his own oil changes. I didn't do my own until I got my truck (10 years of driving). Just saying that it is a rip-off, so that kind of price doesn't surprise me, and it doesn't sound like much more than a full synthetic oil change performed at a business.
  15. Apr 20, 2011 at 8:56 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Wow, I have never heard of that before. How long have you been doing that?
