Does the OEM bottle jack work on 2” lift and 33’s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by junkyarddogg, Jul 19, 2023.
  1. Jul 19, 2023 at 11:41 AM
    junkyarddogg
    junkyarddogg [OP] Well-Known Member
    New Jersey
    2021 TRD Off Road
    Or do I need to place it on a block?
  2. Jul 19, 2023 at 11:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yup. If you place it under the LCA / axle.
  3. Jul 19, 2023 at 11:45 AM
    sultan_of_sludge
    sultan_of_sludge Well-Known Member
    ZK
    2001 Tacoma TRD
    You're DEFINITELY gonna need a block.
    Don't forget the jack stands..
    (or be mindful of where your limbs are)
    Chew likes this.
  4. Jul 19, 2023 at 12:08 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    You only need a block if you are trying to reach the frame. if put under the rear axle between the diff and tire it should reach. and placing under either front lower control arm is fine as well.
    Bertlow, MR E30 and Shellshock like this.
  5. Jul 19, 2023 at 12:18 PM
    sultan_of_sludge
    ZK
    2001 Tacoma TRD
    In an emergency sure it would work. Jacking up the truck enough to change a tire using the axle as a jack point with a contact point as small as what you get with a bottle jack is just sketchy as hell. I wouldn't want to do a brake job like that. Just my $0.02.
  6. Jul 19, 2023 at 12:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Your lift has no effect assuming you have shocks with the same extended length, but the 33 in tires add about an inch. At least one person has reported the stock jack works with 35’s.
    Junkhead and AmateurTaco1313 like this.
  7. Jul 19, 2023 at 12:25 PM
    Shellshock
    Iowa
    It’s a lot safer than all these people using high lifts
    if you are doing maintenance, get some jack stands.
    tonered and YF_Ryan like this.
  8. Jul 19, 2023 at 12:29 PM
    sultan_of_sludge
    ZK
    2001 Tacoma TRD
    I do not own a high lift jack for that reason. (They do look cool though)
    And it's A LOT easier to throw a jack stand under the truck than to jack up a truck that fell off a bottle jack onto your driveway with a wheel off. Ask me how I know.
    This is why I can't condone sketchiness with a bottle jack. I am also lucky to still have my leg.
    auskip07 likes this.
  9. Jul 19, 2023 at 12:34 PM
    YF_Ryan
    Kent, WA
    Last time I put a block under my jack, the block broke in half, lol. I thought it was a perfectly fine piece of 2x6 (fresh from lumber used for building a shop). But yeah, obviously it's good to use a jack stand. Unless I hear otherwise from the OP, i think he's probably just meaning if he gets a flat tire. Most of us don't carry a jack stand for that situation, even if we should.
  10. Jul 19, 2023 at 12:35 PM
    YF_Ryan
    Kent, WA
    Hi-lift has been great for me doing maintenance on my truck. My ARB has cutouts for it, so a quick lift on my driveway (good straight up angle with a flat surface), then jack stands underneath. I know they can be dangerous, but most of it can be mitigated through proper use.
    sultan_of_sludge likes this.
  11. Jul 19, 2023 at 12:41 PM
    sultan_of_sludge
    ZK
    2001 Tacoma TRD
    You mean you weren't using a block of old growth Oak?! SMH! :rofl:
  12. Jul 19, 2023 at 12:51 PM
    Shellshock
    Iowa
    Yup agreed. Most people ignore that last part though lol
  13. Jul 19, 2023 at 1:03 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Woah! Glad you are OK. Yeah, if I don’t have a Jack stand handy, then I put the spare under the frame near where I am working as a emergency stand and later swap it with the flat wheel when I am out on the road and have to change a tire.
    YF_Ryan, Shellshock and Toolndie7 like this.
  14. Jul 19, 2023 at 1:05 PM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    Whenever I am outside the comfort of the garage and jack stands while swapping a tire I always slide the dismounted tire under the frame as a little added insurance.
    EDIT apparently I typed too slow
  15. Jul 19, 2023 at 1:10 PM
    Tacospike
    Two Trucks
    Is OP using the hitch?
  16. Jul 19, 2023 at 1:11 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Will your spare tire and wheel fit?
  17. Jul 19, 2023 at 4:12 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Having a block might help level the jack from uneven ground
  18. Jul 19, 2023 at 4:43 PM
    junkyarddogg
    New Jersey
    2021 TRD Off Road
    Yup, this is strictly for emergencies to change a flat if on the road. Sounds like it would work although maybe not ideal. I just don't want to carry a big heavy jack around. Maybe a 2x4 would work.
