Does the Power Probe BA10 Adapter fit the the 2nd Gen Master Cylinder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hawkvenom, Mar 16, 2015.
  1. Mar 16, 2015 at 10:38 AM
    Hawkvenom
    Hawkvenom [OP] Member
    Does anyone know if the Power Probe BA10 top fits the master cylinder of a 2012 Tacoma? Im planning to bleed my brakes and buying a motive bleeder soon. Any input is appreciated. Thanks.
  2. Mar 16, 2015 at 11:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you have a TRD OR 4x4 with atrac? (trying to determine if you have the electric boosted master cylinder or vacuum boosted)
    If you have the electric boosted your life is EASY. Simply turn the truck on but not running, open the bleeder screw and have a friend put a little pressure on the pedal. The electric booster will literally pump fluid through the line at an alarming rate... makes bleeding so damn easy.
  3. Mar 16, 2015 at 11:47 AM
    Hawkvenom
    Thanks for the reply. I just have the standard 4X2 Prerunner v6. I can check when I get home.
