Does the SC kit require oil coolers?
Discussion in 'Underdog Racing Development' started by Revelations, Jun 20, 2014.
  1. Jun 20, 2014 at 4:08 PM
    Revelations
    Revelations [OP] Well-Known Member
    2014 MGM DCSB
    Does your supercharger kit require the 05+ tacomas to have engine & transmission oil coolers like the ones found in the trucks with tow packages?
  2. Oct 6, 2014 at 9:48 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    We recommend that if you go stage 2 or higher you should install the Toyota OEM engine oil cooler if your truck does not already have it installed. That engine oil cooler does a very good job of stabilizing engine oil temperature.
    I have been running the URD Stage 2 system on my 4Runner for about 90,000 miles and have not added a supplemental transmission cooler.
    G
