Does the tranfer case chain spin in 2WD on a 2nd gen Tacoma ?
Discussion in 'Technical Chat' started by OZ-T, Jul 23, 2013.
  1. Jul 23, 2013 at 10:18 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    A search resulted in conflicting answers
    Thanks in advance
  2. Jul 23, 2013 at 11:41 PM
    OZ-T
    Peter North
    British Columbia
    before bed bump
  3. Jul 24, 2013 at 7:13 AM
    OZ-T
    Peter North
    British Columbia
    Anybody help me out here ?
  4. Jul 24, 2013 at 7:16 AM
    Round II
    Round II Member #12005
    I would think that the TC chain would not spin as you're basically putting the TC into N in 2WD, yet I may be wrong?
  5. Jul 24, 2013 at 7:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It shouldn't because you can spin your front driveshaft by hand when the truck is parked. If it does spin, it's because things around it are spinning causing it to spin free. It shouldn't spin with any power though. Just my observation though, I could be way off base as I've never torn apart my transfer case to study the inner workings.
    You thinking that's the noise you're hearing?
  6. Jul 24, 2013 at 7:27 AM
    OZ-T
    Peter North
    British Columbia
    Yes , in the video the noise sounds exactly like a chain going around a sprocket , but I was in 2WD
    Going to put it on my buddy's hoist this morning and try to figure it out
  7. Jul 24, 2013 at 7:27 AM
    OZ-T
    Peter North
    British Columbia
    Thanks
  8. Jul 24, 2013 at 7:29 AM
    Round II
    I would give this a test for ya but I have a gear driven TC. What I have found sorta backs up my thinking but again may not be correct?
    "In short, your drive shaft out of the centerdiff/transfer case should NOT spin under the engine's power while in 2wd with ADD"
    __________________
  9. Jul 24, 2013 at 7:34 AM
    OZ-T
    Peter North
    British Columbia
    I agree the driveshaft does not spin , that was evident in a video I took of the underside of my truck , I was wondering if the chain turns in 2WD
    ie : when the front driveshaft is disengaged in 2WD , is the chain stopped or does the chain turn still
  10. Jul 24, 2013 at 7:38 AM
    Round II
    Yea and being that the front DS is not "spinning" in 2WD I would believe that the the chain drive would be disengaged as well? I think this to be the case as I know that my gear driven case make no whine when in 2WD? Again all speculation? :confused:
  11. Jul 24, 2013 at 7:41 AM
    OZ-T
    Peter North
    British Columbia
    Makes sense , I was just unsure what was disengaged in the transfer case in 2WD
    Thanks
    I'll post back what we find later this morning
  12. Jul 24, 2013 at 7:44 AM
    Round II
    Nice.
  13. Jul 24, 2013 at 7:45 AM
    Pugga
    Massachusetts
    You can test this easily enough. Through the X-fer case fill port, you should be able to see the chain. Have someone look inside and then spin the front DS by hand. If the chain spins with it, then you know if the front DS is not spinning, the chain isn't either. If the chain does NOT spin with the DS, then you'll know that there's a very good chance that the chain is spinning under power even when the front DS is not spinning.
  14. Jul 24, 2013 at 7:47 AM
    OZ-T
    Peter North
    British Columbia
    Sounds good
    Thanks
  15. Jul 24, 2013 at 10:27 AM
    OZ-T
    Peter North
    British Columbia
    OK
    As you guys suggested , no chain movement in 2WD
    Thanks again
  16. Jul 24, 2013 at 1:54 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So whats the problem you having ?
  17. Jul 24, 2013 at 1:57 PM
    OZ-T
    Peter North
    British Columbia
  18. Jul 24, 2013 at 6:48 PM
    Taco'09
    Taco'09 Well-Known Member
    There was a rather heated discussion about this same question going on over at TN. I've seen quite a few lifted 4WD trucks going up the hwy. that have their front drive shafts spin at a small fraction the speed of the rear -- apparently due to friction within the gear lube in the front diff. leading to spinning the ring/pinion gears a bit. Since the front DS is connected by the chain's output shaft it might be that the answer is yes and no. No in theory, but yes in reality albeit somewhat slowly within the transfer case.
    Edit: Oops, missed your comment that the condition was front DS disconnected. You might want to look at the pic at TN. The question being could gear lube friction within the TC rear output shaft still spin the chain slowly in 2WD?
  19. Jul 25, 2013 at 8:10 AM
    Round II
    Try checking the play in the drivers side CV. I was having an issue just as said and though the steering wheel stayed true (No vibes) I too was getting the same thing as you described in your OP thread. (01) was the fact that I had the ADD locked so the drive train was spinning in 2WD (02) the needle bearing was soooo toast that is was exasperating the vibe.
  20. Jul 25, 2013 at 8:44 AM
    OZ-T
    Peter North
    British Columbia
    Thanks
