Does the V6 alternator fit on the 2TR-FE engine?
Discussion in '4 Cylinder' started by TireFire, Jul 29, 2016.
  1. Jul 29, 2016 at 2:57 PM
    TireFire
    TireFire [OP] Superunknown Member
    Olympic Peninsula
    wondering if I can take the 130amp alternator out of a 2005 to 2015 wrecked V6 Tacoma (1GR engine with tow package) and bolt on a 4banger.
    I realize the need to upgrade wiring which is a non concern. I want to know if the belt and bolts etc would fit...
    Any input or anyone possibly done this?
    mahaloTaco likes this.
  2. Jul 29, 2016 at 3:51 PM
    TireFire
    Olympic Peninsula
    I know it is mounted on the other side of the engine but can it still fit?
  3. Jul 30, 2016 at 5:17 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    The alternate from an es300 looks a lot closer
  4. Aug 4, 2016 at 1:31 PM
    TireFire
    Olympic Peninsula
    How much output?
  5. Aug 5, 2016 at 7:23 AM
    tgear.shead
    tgear.shead Well-Known Member
    Why do you think you need a bigger alternator? I run an electro-hydraulic snow plow pump on mine, no issue with providing adequate power from the factory alternator.
  6. Aug 5, 2016 at 9:55 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    My problem is mainly from my sub which is 600 watts which in terms of subs isn't that much but I do get flickers when I'm at idle. I also have a bunch of lights too lol
  7. Aug 5, 2016 at 10:01 AM
    tgear.shead
    Flickers? Probably a wiring problem, not alternator inadequacy. If your battery was being depleted, then you'd look at whether or not the alternator is able to keep up, but the battery should be adequate to keep your audio going without making the car flicker. Try wiring the sub straight up to the battery temporarily, to see if the "flicker" goes away. If it does, then you need to focus on the balance of the circuit.
    power / voltage = current.
    600/12 = 50 amps. This is the PEAK current that your amplifier can ever draw when the volume is cranked up high enough to cause you to go deaf. That is considerably less than your alternator's output. Add to that, that your battery can dump out several HUNDRED amps, and you should not be experiencing any flickering.
    tubbsisland likes this.
  8. Aug 5, 2016 at 10:19 AM
    TireFire
    Olympic Peninsula
    Bump for getting this thread back on topic plz
  9. Aug 5, 2016 at 10:20 AM
    tgear.shead
    Didn't even notice that I wasn't replying to OP there.
    How about you go ahead and answer the question?
  10. Aug 5, 2016 at 10:23 AM
    TireFire
    Olympic Peninsula
    What question? I asked a question that I'm still trying to find an answer to ...
    davidstacoma likes this.
  11. Aug 5, 2016 at 10:24 AM
    tgear.shead
    The one I asked you in post 5.
  12. Aug 5, 2016 at 10:28 AM
    TireFire
    Olympic Peninsula
    Bc my alternator only puts out 70amps
  13. Aug 5, 2016 at 10:30 AM
    tgear.shead
    That's not a reason.
  14. Aug 5, 2016 at 10:30 AM
    TireFire
    Olympic Peninsula
    Same as the standard V6 alt. Tow package gets 130amps and both fit so...
  15. Aug 5, 2016 at 10:31 AM
    tgear.shead
    So you want to see if you can spend some money for no reason?
  16. Aug 5, 2016 at 10:31 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    If you don't want to answer the dudes question that's fine, move on. He doesn't owe you any explanations.
    Ruggybuggy likes this.
  17. Aug 5, 2016 at 10:32 AM
    tgear.shead
    What's your problem?
  18. Aug 5, 2016 at 10:33 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    That you're being a dick for no reason. He asked for help with a question, not an analytical assessment of why he's asking it.
    Juisebocks and TireFire[OP] like this.
  19. Aug 5, 2016 at 10:33 AM
    TireFire
    Olympic Peninsula
    Dude! Either help or leave. I don't have to justify nothing to you, with all due respect.
    But if you must know it's because I need more than 70amps so I don't run my battery down all the time
  20. Aug 5, 2016 at 10:36 AM
    tgear.shead
    You don't think it would be a better idea to solve the issue that is overdrawing your charging system than to throw more current at it?
