does this lift sound good?
Discussion in 'Suspension' started by bradicus8, Sep 18, 2012.
  1. Sep 18, 2012 at 2:07 AM
    bradicus8
    bradicus8 [OP] Well-Known Member
    Brad
    Buena park, CA
    Ive been thinking about going with the revtech 3' spacer for the front and 1 1/4' for the back... should I go with the diff. drop kit or rear AAL?? I was thinking AAL... And if I go with this im keeping stock shocks... not gonna do any off roading, just going for that aggressive look for something thats not gonna kill my wallet, also I want to be able to put some 285's on there too. let me know if im on the right track guys! and if not tell me what I should do! thanks!
  2. Sep 18, 2012 at 2:10 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Quinton
    Rollin' Tides and Bangin Brides.
    01 TRD xtracab, lifted, sitting on dem dirty turty trees, actually they are clean.
    Stuff. Things as well. I like putting these on instead of those. You know, for likes.
    Well, since cost is a major factor...how much is this kit?
  3. Sep 18, 2012 at 2:12 AM
    Roll Tide
    Quinton
    Diff drop won't lift any...so yes to the AAL. Spacer lift will make it ride rougher. A coil over lift will either be as good or better than stock on ride quality.
  4. Sep 18, 2012 at 2:12 AM
    bradicus8
    Brad
    Buena park, CA
    its 315$ on performanceparts4less
    also, I hear sometimes people on TW saying they have a 3' lift but it doesnt look like much... should i consider a 4'?
  5. Sep 18, 2012 at 2:19 AM
    Roll Tide
    Quinton
    Well when you lift 3" and stuff a 2 " taller tire in the fender, it doesn't look like much, but you can tell every time you get in...hahaha. I went with the "ultimate lift kit" that came from Toytec because I didn't want to sacrifice ride quality and I didn't want to use a spacer lift because over time it will wear on your stock coil spring. If you go higher than 3" you will have issues with your CV axles. Lots of vibrations. My lift was $1000 and I got quality parts. No vibrations, great ride and plenty of lift to fit 285's.
  6. Sep 18, 2012 at 2:39 AM
    bradicus8
    Brad
    Buena park, CA
    nice, I was checking that out right now on toytech, looks like ive got some decision making to do here.. do I care about ride quality? yes.. do I want to save my money? YES... do I want to sacrifice quality? no... is the look the most important thing? yes... saving money and buying a kit that may have negative affects on other parts later? not worth it haha
  7. Sep 18, 2012 at 2:42 AM
    Roll Tide
    Quinton
    Pretty much.
  8. Sep 18, 2012 at 3:37 AM
    Roll Tide
    Quinton
    There is an icon lift for sale in 1st Gen...
  9. Sep 18, 2012 at 6:33 PM
    bradicus8
    Brad
    Buena park, CA
    I got an 06 DC Pre runner though, would that kit work?
  10. Sep 18, 2012 at 6:45 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    No, the 1st Gen kit won't work. I wouldn't spend the money on the spacer kit. Just my $0.02. For a prerunner, I'd give spindles some serious consideration.
  11. Sep 18, 2012 at 6:47 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver
  12. Sep 18, 2012 at 6:51 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This
  13. Sep 18, 2012 at 6:56 PM
    bradicus8
    Brad
    Buena park, CA
    I've been checking out the Maxtrac 4" spindle... Seems like a good way to go, maybe some 5100's in the front and an AAL 2.5" for the back? What do u think
  14. Sep 18, 2012 at 6:57 PM
    OZ-T
    Peter North
    British Columbia
    or spindles
  15. Sep 18, 2012 at 6:59 PM
    Pugga
    Massachusetts
    F-150 Mod
    You can piece them together and use the stock front suspension for a while. For the rear AAL, I'd recommend the Icon or Wheeler's 3-leaf AAL or a replacement leaf pack like the Dakars.
  16. Sep 18, 2012 at 6:59 PM
    bradicus8
    Brad
    Buena park, CA
    I've heard good things about the OME kit but I'm not sure if that will be enough lift for me, anything I could do to make the lift higher after putting I'm the OME? Or at that point would I be better off going with spindles?
  17. Sep 18, 2012 at 7:00 PM
    OZ-T
    Peter North
    British Columbia
    If you want over 2 1/2 - 3" spindles are probably your route
  18. Sep 18, 2012 at 7:01 PM
    bradicus8
    Brad
    Buena park, CA
    So I don't even have to get billies for a while? Just the spindles and the AAL?
  19. Sep 18, 2012 at 7:02 PM
    bradicus8
    Brad
    Buena park, CA
    I'm thinking thats probably where I'm going with this
  20. Sep 18, 2012 at 7:02 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    sub for info
