Does this look like an issue...?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alesimo, Apr 21, 2018.
  1. Apr 22, 2018 at 6:22 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I think they only confiscated the trucks under recall, not the ORs and Pro trucks with leaky diffs that were fixed under warranty and not recall.
    Spare Parts[QUOTED] likes this.
  2. Apr 22, 2018 at 7:16 AM
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
  3. Apr 22, 2018 at 8:58 AM
    RustyTacos
    RustyTacos Well-Known Member
    CJ
    kentucky
    17 MGM TRD Sport 4x4 MT
    Off roads pros and manual trans trucks are not under the H0G recall. what kind of gas mileage are you getting to think you have a hole in your gas tank?
  4. Apr 22, 2018 at 12:33 PM
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Went from 17ish to 14 on the last 2 tanks. Can't even get 300 miles on the tripmeter.
  5. Apr 22, 2018 at 12:41 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Don't worry what the computer says, calculate how much you fill and how much you burn by miles travelled to get an accurate amount.
    Any mods or is the truck stock?
    Stop and go driving or highways? If highway what speed are you driving?
    My truck usually gives me 386 miles on the computer to go til empty, the last fill up gave me over 400 miles but by actual calculations I'm averaging 21 mpgs after 2 years.
    itsmermf likes this.
  6. Apr 22, 2018 at 12:45 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I noticed your a Manual. Made me think what are the optimal shift points? I know we give up some mpgs, but that's a lot.
  7. Apr 22, 2018 at 12:46 PM
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    280 miles on trip, 19 gallons on fill up= 14.7. when filling up it says I'll get 368 (changed from 353). I have a roof rack, mud flaps, and ditch lights. And I drive maybe 70.
  8. Apr 22, 2018 at 12:47 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yep, running out the gears like you're a drag racer will drain the tank quicker.
  9. Apr 22, 2018 at 12:47 PM
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    Optimal are probably 3-3.5. I tend to stay a tad lower, around 2-3000 rpm.
  10. Apr 22, 2018 at 12:48 PM
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    And good Lord, this isn't the first time I've driven a vehicle. I understand when you ask for more, you pay more. This isn't the case.
  11. Apr 22, 2018 at 12:49 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    What roofrack, the OEM? Try lowering the speed, I can only average 55-65 on my daily 40 mile commute (1800 rpms) for my 21mpgs and I have the OEM roofrack, sliders, a bed toolbox full of stuff and 2 inch lift.
    Alesimo[QUOTED][OP] likes this.
  12. Apr 22, 2018 at 12:52 PM
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    Frontrunner. I try and keep them down. The issue is, I've had the truck for over a year and now it's fallen on it's face.
  13. Apr 22, 2018 at 12:54 PM
    Spare Parts
    Southern Maine
    Ya thats where I am typically, but the truck likes 3k plus, I am wondering if it would make a difference to stay up there more.
  14. Apr 22, 2018 at 12:55 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Slow down and see if the mileage improves, also winter gas has about a 20-25% mpg decrease.
  15. Apr 22, 2018 at 12:56 PM
    #35
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    I'm always down for that haha. I do think it's a mixture of winter fuel and the rack (maybe). It would be sweet if they fixed the diff and it improved ha
  16. Apr 22, 2018 at 12:58 PM
    #36
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    They'll fix the diff, just not the same day you take it in unless you're lucky and they have the parts onhand.
    Frontrunner rack at 70 ain't helping. How long has the rack been on the truck?
  17. Apr 22, 2018 at 1:00 PM
    #37
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    The rear diff in my 16 started seeping recently. Never received a recall notice. I torqued the nuts, none were loose. On the positive side, this is the last excuse I needed to install 4.88s.
  18. Apr 22, 2018 at 1:00 PM
    #38
    Alesimo
    Alesimo [OP] Jeeper
    Alec
    Houston, Texas
    I think December
  19. Apr 22, 2018 at 1:04 PM
    #39
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Any sort of deflector on the front of the rack, any stuff in the rack?
    Still running stock tires right?
  20. Apr 22, 2018 at 1:08 PM
    #40
    VTSR516
    VTSR516 Well-Known Member
    Vermont
    2016 SR5
    NEW: LT265 75 R16 General Grabber AT2's Hood and window deflectors ARE cab high color matched CX series cap weathertech floor mats Rough country 30" 15,000 lumen light bar in front grill
    It's a warranty issue. They WILL fix it for free.....Common issue with a lot of early Gen 3's
    Alesimo[OP] likes this.
