Does this look right?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LEGITacoma, May 8, 2012.
  1. May 8, 2012 at 1:54 PM
    LEGITacoma
    LEGITacoma [OP] Well-Known Member
    Louisiana
    99 Tacoma Prerunner
    Rockford Fosgate T0 in a Ported Box, Hifonics 1000.1, Pioneer AVIC Z-120BT Headunit w/ Rearview Camera
    I ordered a 3 inch spacer lift with 1 inch rear blocks (http://fatbobsgarage.com/i-6765338-...it-w-rear-blocks-4wd-2wd-1996-2004-6-lug.html) for my 99 Tacoma Prerunner from Fat Bob's Garage and the spacers don't look like they will give 3 inches of lift. The rear blocks look like the correct thing but idk about the spacers. Maybe I'm wrong so if anyone could help I would appreciate it. Here are some pictures of it.
  2. May 8, 2012 at 1:55 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Yes, that's right, the spacer compresses the strut which gives your the 3ish inches of lift.
  3. May 8, 2012 at 1:57 PM
    LEGITacoma
    Louisiana
    99 Tacoma Prerunner
    Thanks alot man. Good to know that its the right one. Also thanks for the quick reply. Fat Bob's did some A+ packaging by the way and I was really impressed. It wasn't all just thrown in the box like I expected.
  4. May 8, 2012 at 1:59 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    They are correct.
    Front 1.5" block = 3" lift
  5. May 8, 2012 at 2:00 PM
    XXXX
    sKiP
    05 Prius
    it's not a coil spacer so no compression.
    stock ride feeling
  6. May 8, 2012 at 2:00 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    double the size of the spacer to get how much it will lift
  7. May 8, 2012 at 2:03 PM
    scocar
    scocar Patron of the Farts
    You need to remember that this block on top of the coil assembly is pushing the inside (closer to the pivoting bolt) of the LCA down. The outer tip of the LCA is being pushed own proportionately farther, because it is rotating around the pivoting bolt.
    Think of a door in your house. Push it close to the hinge just a little bit, and the outer edge of the door (with the door knob) moves farther.
