Does this seem like an engine or drivetrain issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sealfab, Aug 26, 2025.
  1. Aug 26, 2025 at 5:13 AM
    sealfab
    sealfab [OP] Well-Known Member
    North Virginia
    2006 DCSB TRD
    My 2015 4.0 automatic with 130k started "clunking" recently, yes I know clunk is quite vague bear with me. It never happens under acceleration or in stop an go conditions. Its always while maintaining speed anywhere from 30mph seemingly while the trans is in overdrive. There will be a quick hesitation/mild knock and than back to normal, if I put it in 4th it does not happen but that always tends to keep it out of the RPM range where it typically occurs which is around 1300. There is no CEL present.
    Any ideas?
  2. Aug 26, 2025 at 6:55 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like torque converter shudder. Some guys have had luck adding LubeGuard to the transmission fluid
  3. Aug 26, 2025 at 6:57 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    How about the mid-shaft support bushing on the driveshaft?
    JohnDoeFasho likes this.
