Does this sound doable?
Discussion in 'Lighting' started by PeteK, May 27, 2009.
  1. May 27, 2009 at 7:41 AM
    PeteK
    PeteK [OP] Well-Known Member
    Brockton, MA
    2017 Cement Truck
    I have 2 PIAA 520 Driving and Fogs arriving shortly. Seeing how I only have 1 blank spot for a switch for the lights and didn't want to do major surgery to add switches, I was hoping to do the following. Let me know if this sounds doable.
    My goal:
    1. Have the normal stock truck lights come on and off whenever I want
    2. Have the PIAA driving and/or fog lights on whenever I want
    What I'm looking to do:
    1. Wire the stock fog lights into the stock headlights, so that when the headlights are turned on, both headlights and fog lights come on (I always run with both on anyway)
    2. Wire the PIAA fog lights into the open switch that will be placed under the climate controls. This will be able to be turned on at any time, regardless of the state of the stock headlights. (still deciding on whether I want them to turn off with the ignition)
    3. Wire the PIAA driving lights into the stock fog light switch. This will be able to be turned on at any time, regardless of the state of the stock headlights. (still deciding on whether I want them to turn off with the ignition).
    It probably is doable, I just wanted to run it by the experts here before I get started. Let me know if there are any hazards I should look out for.
  2. May 27, 2009 at 7:47 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Isn't the point of fog lights (when used in fog) to be minimal low mount lighting. You would loose that functionality in your proposed setup.
  3. May 27, 2009 at 7:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do some research about your states laws about lighting.
    Depending on your state laws on lighting & vehicle inspections (if you have any) - might change the way you wire everything up.
    In PA - driving lights can only be legally lit with the high beams. Fog lights can only be legally lit with the low beams. My fogs are wired illegally - however - for my yearly state inspections, I have to remove power from the fog lights (pull fuse) in order to pass inspection.
  4. May 27, 2009 at 7:57 AM
    PeteK
    Brockton, MA
    2017 Cement Truck
    That is the reasoning in #2 that I can have all lights off except the PIAA fogs.
    Looking to have:
    1. All lights off
    2. Only parking lights on
    3. Only stock fogs and driving lights on
    4. Only PIAA driving lights on
    5. Only PIAA fogs on
    6. Any combination of the above, whether PIAA fogs and parking lights on, or stock lights and PIAA driving lights on, etc.
  5. May 27, 2009 at 8:07 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    you could wire the new fogs to the current ones, then wire a switch for just the driving lights....i wired my 510's to the stock wiring and switch, but i had removed my stock fogs in the process. i have 2 8.5" lights to wire up to a seperate switch that will go to a blank on the left of the steering wheel
  6. May 27, 2009 at 8:10 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    was wondering if you could do that --> 510's to factory fog wiring
  7. May 27, 2009 at 10:02 AM
    The_Hodge
    SC
    yeah...i cant remember what the colors are, but they're not red/black. luckily i wired them right the first time. just chopped off the stock connector
