Does this sound like a dealership rip-off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DoomCrew, Sep 1, 2013.
  1. Sep 1, 2013 at 5:51 PM
    DoomCrew
    DoomCrew [OP] New Member
    Jonny5
    Simi Valley
    2011 Double Cab 4x4 longbed
    Not enough
    Ok, I have been a toyota owner my whole life and have done all my own work, from suspension to engine swaps. My situation is... My mom owns a 2010 Tacoma double cab 4x4 and has also been a toyota owner her whole life from the old land cruiser to this taco. She is now 60 years old and takes her taco to the dealer for service. She recently took it in for a vibration, and they told her there was a drive train problem and that the driveshaft need to be replaced so I asked why and they posted pics of a u-joint that was bad. So I'm thinking its only going to be a few hundred to replace a u-joint at the dealer. But no they replaced the whole drive shaft from the trans to the axle. Also at the same time they told her that the front differential was bad and needed to be replaced so I was like wtf you know! so they replace the whole front dif and they charged her 3700 hundred for this work. I told her to make sure they give her the old parts not know exactly what they were changing. I looked at the drive shaft witch they charged her 900 to replace and all that looks wrong with it was the center u-joint, they changed the whole front dif, I looked at that and it looks and spins smooth, maybe there's a bad bearing in it but they just changed it instead of fixing the problem. All together $3700 for someone who recently lost her job. Doesn't sound or look right to me! At the same time they also pulled off her license plate frames and put their own on. I am wondering if this makes any sense to anyone else. And is this common procedure? I also own a 2011 tacoma double cab long bed 4x4, this is my first post, I hope I'm doing this right and sorry I might have gone back and forth a little.
  2. Sep 1, 2013 at 5:57 PM
    BamaToy1997
    Bill
    Navarre, FL
    I would contact the dealership's service manager and ask for more information, and if that did not get you sufficient answers, to speak with the owner. While it does seem a bit strange, we obviously do not know exactly what it is that they found, or their reasoning for replacing two major pieces that can usually be repaired. More answers from them are what you need.
    As for the license plate cover, that is a common thing at dealerships that I never agreed with. We were always told in the service department to replace the rear plate cover no matter what. I told the manager to bite me, and that NOBODY on my team would be replacing them. If there was NO plate cover, we would install one, but if the customer had an existing one, I refused to change it.
  3. Sep 1, 2013 at 5:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That dealership really took advantage of your mom. There is absolutely no reason to replace an entire drive shaft just because a $20 u-joint is bad. Same with the front differential. Chances are, it was just a seal or bearing that was bad that needed replacing. Replacing the whole differential was unnecessary unless there was a serious, deep rooted problem with the gears or the housing. The license plate thing is just bullshit... they shouldn't have touched the plates and removed the old ones, there's no reason for that.
    This is one of the biggest problems with dealerships. They don't always have the expertise to diagnose and replace parts so they instead replace an entire assembly because it's easier for them. The u-joint is a perfect example. They replaced the entire shaft flange to flange rather than the $20 problem part.
    If I were you, I'd make a complaint with the service manager (and possibly the BBB if you can't resolve it with the dealership), it sounds like they really took advantage of your mom and I'm sure others have experienced the same treatment.
  4. Sep 1, 2013 at 6:23 PM
    lowcountrytj
    lowcountrytj Third Member
    Phillip
    Probably at Work
    2012 DCLB TRD SPORT "BLACKOUT"
    Yeah, I would def go back with the truck and removed items. I would have them explain everything they diagnosed to be an issue.
    How many miles are on your mother's truck? Has anything been modded on it by chance? Does she wheel it by chance? A 2010 with that needing to be replaced just isn't right....don't get me wrong, I have seen crazier. I hope yall get to the bottom of it.
  5. Sep 1, 2013 at 7:24 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    In your State, are they allowed to perform work without permission from the owner? I know what I was going in for then I would sign for the work that was being completed before it was done. I didn't think that they were allowed to perform anything "extra" without the signature of the customer/owner?
  6. Sep 1, 2013 at 8:57 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Why isn't this done under warranty? Drivetrain is covered under the 5yr/60K miles warranty.
    You're suppose to ask these questions BEFORE they do the work. Not after authorizing them to do it.
    Not to mention, they gave or should have given estimates before doing the work.
    Since the OP wasn't there when it all happened, his POV is shit out of luck.:(
  7. Sep 1, 2013 at 9:02 PM
    169.254.255.201 Well-Known Member
    Interwebs
    I think you meant they make more money off it.. Why charge $40 dollars labor, plus $8-10 bucks profit on a u-joint when they could charge you $3000 labor, plus $100 profit on a entire shaft?
    OP. I wouldn't settle for 20% off, and a free oil change.. Maybe paying 10% of the bill... Start a case with corporate or whoever.
  8. Sep 1, 2013 at 9:20 PM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    File a claim with Toyota motor corp. They will give you a claim # then keep calling them to find out the status of the claim. This should get you some better answers. Dealerships don't like when corporate comes around asking questions about fraud.
  9. Sep 2, 2013 at 5:14 PM
    Pugga
    Massachusetts
    No, I really mean it's easier for them. Dealerships around me absolutely would NOT replace my LCA bushings for me. Instead, they would only replace the entire arm which, when purchased from Toyota, has bushings and ball joints pressed in already. Dealerships are not specialty shops and they sometimes won't tear down an assembly to replace a smaller part but instead will replace the entire assembly. They simply fix the problem, not always the most economical way.
  10. Sep 2, 2013 at 5:34 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    ^This, and that's not just Toyota Dealers. The A/C in my brothers Focus quit, Ford dealer said the entire HVAC system had to be replaced. Thankfully he brought the quote back to me and after 10min of looking I realized it was just the power leading into the HVAC. Part cost $20 and less then 15min of my time. Caveat emptor...
  11. Sep 2, 2013 at 5:38 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I don't have anything to add to the OP's situation but I admire your honesty and work ethic. Things that seem to be missing sorely in today's society.
  12. Sep 2, 2013 at 5:42 PM
    fenway.park27
    fenway.park27 Well-Known Member
    Al
    CT
    09 TRD off road access cab
    Front and rear Weathertech floormats, ImMrYo Rear-View Mirror Bracket, anytime fog lights, always on cigarette lighter & power outlet mod, center console and glovebox organizer, LED map and dome lights, Flyzeye LED, Fumoto oil drain valve, FT-8800 ham radio, tailgate theft mod
    When in doubt, get a second opinion.
  13. Sep 3, 2013 at 7:59 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    x2
    How about GM..dealer tells me that the head on my truck (replaced under warranty) caused other parts to fail and he can't comp those but GM will refund me if I call them. Well GM said no, he could have called and done it. The service mgr says he isn't in the business of working for free, and the owner backed him saying it's not worth his time to try and goodwill things. 2 kids in the kitchen next to a broken cookie jar..
  14. Sep 3, 2013 at 8:01 AM
    ABA180
    East Bridgewater MA
    Not the biggest issue in this thread, but if I ever find out my cover is changed at the dealer then someone is going to have a serious problem when I find out about it..when you remove my cover that is my personal property
  15. Sep 3, 2013 at 8:16 AM
    Pugga
    Massachusetts
    x2, but I also have college plate holders. If any dealership ever removed them I'd plant my foot up their hindside.
  16. Sep 3, 2013 at 11:11 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    This is what I was wondering. It should have been covered by the drivetrain warranty.
  17. Sep 3, 2013 at 11:24 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If it involves giving the dealership any money at all, to fix anything, ever, then yes, it is a rip-off.
  18. Sep 3, 2013 at 11:34 AM
    Blacksolid2
    Blacksolid2 Member
    Miami, Florida
    2012 PreRunner SR5
    Smittybilt Sure Step, Tailgate Anti-Theft, AVID Lightbar
    I feel your pain but my issue is with my mothers '04 Ford Explorer 4x4, She broke the shifter off the steering column and the Ford dealer wanted to charge us $1500 for a new steering column instead of a $40 part. I ended up just buying the part myself and having them install it. But now Ford is saying there is a problem with the Throttle Body when i know for a fact nothing else was wrong with the truck when i took it there. It seems to me that dealers are trying every little thing to make more money and screw the customers.
  19. Sep 3, 2013 at 12:03 PM
    ABA180
    East Bridgewater MA
    An extra reason yes but even if it's just a plain Jane it is still my personal property. Do that to my vehicle and someone is going to get seriously injured
  20. Sep 3, 2013 at 12:11 PM
    ABA180
    East Bridgewater MA
    X3..that just don't sound right, although it's very possible to have hit the 60K already there
