Does this sound normal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by duncanaustin1211, Feb 28, 2025.
  1. Feb 28, 2025 at 10:08 PM
    duncanaustin1211
    duncanaustin1211 [OP] Well-Known Member
    Austin
    2019 Tacoma TRD sport
  2. Feb 28, 2025 at 10:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Does it switch on and off with injector modes?
    It does sound worse than usual but its hard to say.
    Oil level good?
  3. Feb 28, 2025 at 10:13 PM
    duncanaustin1211
    Austin
    I honestly don’t know this truck has been a headache I’ve only had it 3 weeks it has fluid over the plastic top cover and on the air filter cover
  4. Feb 28, 2025 at 10:21 PM
    duncanaustin1211
    Austin
    They changed the vacuum pump last week but I just seen this
  5. Feb 28, 2025 at 10:26 PM
    duncanaustin1211
    Austin
    It’s not oil but there is liquid in all those little squares around the air filter and the top plastic cover looks greasy their isn’t a coolant leak because I had a pressure test done.
  6. Feb 28, 2025 at 10:41 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Was everything Clean when you bought it or could this be an accumulation of things over the past 6 or so years?
  7. Feb 28, 2025 at 10:43 PM
    duncanaustin1211
    Austin
    Everything was cleaned spotless I’ve wiped off everything and something is leaking somewhere I just can’t figure it out…
  8. Feb 28, 2025 at 11:57 PM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i'll see if i have this straight.
    you posted (in another thread) typical noisey clacking but with extra clinking after it warmed up (2 videos).
    you said they would change vacuum pump. then you posted this thread after the pump was changed.
    i think what you posted in the first thread did not sound right but what you posted in this thread seems a lot closer
    to what i hear in my 2018 sr5 (though it still hurts me to hear it) and sounds more like the cold engine video.
    as far as the leak: ignoring the yellow gunk on the frame (mud/minor rust?), are you talking about the clear/darker stain?
    and does that seem to be what is on your air filter? if things are spraying, i'd bring it back to shop and ask WTF.
    remember, our oil is real thin and power steering fluid also comes to mind.
    ...and coolant would be pink.
    but as far as the vac pump fixing the clinking, i think it did change something and closer to normal now.
    edit: understandable this feels real bad but if the vac pump cured a problem, and the shop returned it with something spraying - they ought to fix it up pretty easily and you are good to go...may not be as bad as it feels right now.
    Phlogiston and t0p_d0g like this.
  9. Mar 1, 2025 at 2:40 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It doesn’t sound any better than it did before the vacuum pump was replaced. I’m sorry you are going through this but I would take it back to the Chevy dealer and express your concerns.
  10. Mar 1, 2025 at 3:56 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Ugh, looks like a mess
  11. Mar 1, 2025 at 7:41 AM
    duncanaustin1211
    Austin
  12. Mar 1, 2025 at 7:42 AM
    duncanaustin1211
    Austin
    This is completely cold start sounds completely normal the Chevy dealership is giving me the run around saying everything is fine but i don’t believe it’s something internal
  13. Mar 1, 2025 at 7:44 AM
    pdxTacoSR5
    PDX area
    1. before vac pump replace (cold): https://www.youtube.com/watch?v=XzWJ7TaYdTw
    2. after vac pump replace (cold or warm?): https://www.youtube.com/watch?v=RZPUvxu0arA
    i think i hear a difference...but it is subtle and may not be real re placement of camera.
    (2) sounds close to mine and what i have heard from others posting with the usual "is this normal" first post.
    OP just posted another video as i was writing this....and that one sounds normal again. videos from different vantage points are making internet diagnosis, reliable as it is, difficult. :)
  14. Mar 1, 2025 at 7:46 AM
    pdxTacoSR5
    PDX area
    i'd deal with the leak right now.
    edit: your newest video sounds very normal. these are noisey trucks. but again, internet diagnosis....maybe take it to a toyota dealer and ask if you could hear one of their trucks and A/B it with yours.
    kahanabob likes this.
  15. Mar 1, 2025 at 7:54 AM
    duncanaustin1211
    Austin
    Definitely way different from the 94 96 ,99 Tacoma I have owned. lol I’m just going to deal with it till next Thursday taking it to the sister store of Chevy which is Toyota. Lol I could be overreacting but I owe $26,000 :rofl:
  16. Mar 1, 2025 at 8:09 AM
    pdxTacoSR5
    PDX area
    correct. apples and oranges. listen to same engine at toyota dealer. i was freaked out when i bought mine new.
    sounds the same after 6.5 yrs.
    days after i took delivery, i went to toyota dealer and listened to another truck on lot and it was the same as mine.
  17. Mar 1, 2025 at 8:20 AM
    Gfenza89
    All those noises are completely normal, I owned 4 3rd gens they all sounded that way
  18. Mar 1, 2025 at 8:40 AM
    duncanaustin1211
    Austin
    Also, maybe this could be the issue.. So if I press the gas pedal and let go, there’s a hissing sound. If I turn the steering wheel, it makes the same hissing sound… Keep in mind this is in park
  19. Mar 1, 2025 at 8:40 AM
    duncanaustin1211
    Austin
    But I have to turn the steering wheel fast and it makes it hissing sound… Same exact hissing sound when you press and let go of the gas.
    and yes, the power steering fluid is full.
  20. Mar 1, 2025 at 8:45 AM
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Yes the sound is normal, my 2023 SR5 has exact same sound since brand new, its like diesel truck. The leak is definitely not normal and not sure about hissing.
