Does this sound right? Alignment issue with aftermarket UCA's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lundy, Nov 22, 2011.
  1. Nov 22, 2011 at 3:58 PM
    lundy
    lundy [OP] Well-Known Member
    Justin
    Reno, NV
    2010 DBLC 4x4 Off Road
    Recently did 5100/Eibach setup with a 1/2" top plate spacer. Bought the CST billet UCA's (same as Icon) and the alignment shop says I'm out of adjustment and can't get my caster any better than 1.9 on the drivers side but manages to get 2.8 on the passenger side :confused: . Seemed odd to me, I just want to see if anyone else has a similar issue. And yes the alignment shop did kinda muck the bottom of my brand new UCA's :mad:
  2. Nov 22, 2011 at 4:01 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    have them fix, or pay for new ucas if they fucked them up, and there shouldnt be a reason they cant get it in spec, take it somewhere else.
  3. Nov 22, 2011 at 4:01 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    post up the alignment sheet and photos of the position of your eccentric alignment cams.
  4. Nov 22, 2011 at 4:19 PM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    Doesn't sound right at all. Did you have the alignment done at a dedicated alignment shop? Or was it a chain like Firestone? I don't trust the latter. Before I got my aftermarket ucas I had my truck aligned... Took it to firestone first and they couldn't even get it close. Then I took it to a real alignment specialist and he got it in spec easily.
  5. Nov 22, 2011 at 4:21 PM
    lundy
    Justin
    Reno, NV
    These right?
  6. Nov 22, 2011 at 4:24 PM
    lundy
    Justin
    Reno, NV
    It is a dedicated alignment shop. I have a slammed G37 on coilovers and he did that one in less than an hour. He had my truck all day and still couldn't get it right. It's pulling to one side now too. Probably because of the difference in caster. I'll have to try somebody else.
  7. Nov 22, 2011 at 10:40 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    Hope they get it! Keep us posted.. I'm curious too
  8. Nov 22, 2011 at 11:04 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Have the the same issue with the Tacoma. I didn't have much lift on the coilovers when I did the alignment and he couldn't get it anywhere near spec. The truck had a lot of wander on the road too. I've since raised the front and it feels way more stable. I haven't had it realigned yet since I'm waiting on the bumpers to show up for final ride hight adjustments.
  9. Nov 22, 2011 at 11:13 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep, weird. There are four eccentrics - you only showed one and didn't tell us which on it is. But it's a bit odd that the one you showed us is more or less centered, rather than close to maxed out.
    Check your coilover assemblies and make sure the 5100 spring perch is set correctly on both sides, and that your lift height is roughly the same (within 1/4") from hub (not ground) to fender left to right.
  10. Nov 22, 2011 at 11:58 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Are the icon uca designed to correct alignment? I didn't think they were but not sure.
  11. Nov 23, 2011 at 7:42 AM
    lundy
    Justin
    Reno, NV
    All he showed me was the heim joints that we're maxed out and the pictured adjustment. I've only had the truck a few weeks so I'm not familiar where the other three are. Checked the perches and they're both at the second notch .85
  12. Nov 23, 2011 at 7:46 AM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    When I had my truck aligned with Icon UCAs the shop said it was the toughest suspension adjustment they had ever seen. I will try and remember to post my results later.
  13. Nov 23, 2011 at 8:00 AM
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    Are you running your swaybar?
  14. Nov 23, 2011 at 8:33 AM
    lundy
    Justin
    Reno, NV
    Yes. I didn't purchase the the drop bracket either.
  15. Nov 23, 2011 at 9:08 AM
    woods247
    back yonder
    Not sure if the drop bracket would have an effect on alignment but it's a good idea to buy one anyway. A proper shop should be able to get it in spec. It took a while for me to find a competent shop and it turned out to be a place that specializes in lifted 'street' trucks. There's gotta be a similar offroad shop near you that can help. When I finally got mine situated I had to chop the cab mounts because the 285s rubbed like crazy after the castor was in spec.
  16. Nov 23, 2011 at 9:19 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    loose the sway bar you dont need it trust me...and yes i drive 70+ miles a day on highway at 80mph and wheel pretty damn hard and never drive nice...trucks way smoother and nicer to drive without swaybar....may help may not...good luck either way
  17. Nov 23, 2011 at 9:26 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    sway bar wont effect alignment. Did they try adjusting the uppers? Those don't look maxed out to me
  18. Nov 23, 2011 at 10:45 AM
    lundy
    Justin
    Reno, NV
    He said (and it looks like) the heim joints on the UCA's are maxed on the one side. Every time he threaded the heim out on the opposing side to get more castor the camber started going too positive. I don't really speak alignment though but from he said I could see where he was coming from. I just feel like there should be combination of adjustments between the OE adjustments and the UCA adjustments to get it perfect. From what I understood the heim joints are supposed to more versatile?
  19. Nov 23, 2011 at 10:48 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol cst? those look like icon's or some kind of major rip off of the icon control arms.
  20. Nov 23, 2011 at 11:04 AM
    lundy
    Justin
    Reno, NV
    You haven't heard of CST??? CST doesn't do much for Toyota's but their GM kits are superior to any I've seen. Had the 9/11 kit on my company truck and they hooked me up with these. I believe they partnered up with Icon for the UCA just like donahoe looks to have done the same thing.
