Does this truck have a lift?
Discussion in 'Wheels & Tires' started by Les Callahan, Jun 12, 2010.
  1. Jun 12, 2010 at 8:03 PM
    Les Callahan
    Les Callahan [OP] Member
    Seahorse
    Orlando
    08 PreRunner SR5
    Billi 1500 front, Rear TSB , Grillcraft grill, NOBAMA bumper sticker, Wet Okole front seat covers, reversed floor mats (flipped them over, now have durable black mats)
  2. Jun 12, 2010 at 8:35 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    IF i was to guess, Id say he has 5100s at 1 inch to level the truck out more. And has 265/75 Tires. The tires don't look wide enough to be a 285/75. and doesn't have enough clearance either.
  3. Jun 12, 2010 at 8:36 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I would say it's at 1.75" in the front with 265/70/17s.
  4. Jun 13, 2010 at 9:53 AM
    utmck
    utmck Well-Known Member
    From an appearance standpoint.... what is the difference between 265/75/17 & 265/70/17?
  5. Jun 13, 2010 at 10:09 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    The 265/75's would have a slightly larger sidewall, so the tire would be slightly larger. But, most tire brands don't make a 265/75/17.
  6. Jun 15, 2010 at 8:33 PM
    Les Callahan
    Seahorse
    Orlando
    08 PreRunner SR5
    Does a 265/70/16 appear wider than a 265/75/16 ?
  7. Jun 15, 2010 at 8:36 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Not wider, but a bit bigger in general. Since they're both 265's, the will look the same width.
  8. Jun 16, 2010 at 5:59 AM
    crazybayman
    crazybayman Oh 'eah
    Newfoundland
    09 4x4 4.0L V6 Access Cab Standard
    AutoStart, Sirius Satellite Radio, 16x8 Moto Metal 955s, 265/75/16 Duratracs, Fog Lights, Skid plate
    They're exactly the same width. The 265/75 has a higher sidewall.
