Does timing belt really need changed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by southerman21, Oct 30, 2011.
  1. Oct 30, 2011 at 6:56 PM
    southerman21
    southerman21 [OP] Well-Known Member
    Dylan
    SE Ohio
    19 Tacoma DCSB TRD OR
    I have a 2000 3.4l v6 4x4 and it has 140,xxx miles on it. I was wondering if i should change the timing belt or not? I dont think a belt would be that expensive, but i think just by lookin at the engine, that its gonna be a b****
    to change it.
  2. Oct 30, 2011 at 6:57 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
  3. Oct 30, 2011 at 6:58 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Yes and while you're at it you should also change the water pump.
  4. Oct 30, 2011 at 6:58 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    not to bad..I had a guy I work with change mine, took about 2 hours or so. Including water pump, thermostat and the belt.
  5. Oct 30, 2011 at 7:01 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    The single most important belt on the engine. Yes you should change it and if you have 140,000 miles on it I would not drive it again till you changed it. As a rule, anytime you change a timing belt it's always a good idea to change the water pump and any other belts or idler pulleys that are on the front end of the engine.
  6. Oct 30, 2011 at 7:03 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    that is one fast worker. if you don't want any future issues, do your regular maintenance to avoid them. it's not cheap, but it's wise do it.
  7. Oct 30, 2011 at 8:10 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    it's cheap if you do it yourself, but it's a bitch to do...Toyota's are a bitch to do anything on front of engine..whether it be timing belt or front main seal or anything..
  8. Oct 30, 2011 at 8:13 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    The transverse engines are the worst.
  9. Oct 30, 2011 at 8:30 PM
    southerman21
    Dylan
    SE Ohio
    Ok I have done some research and I found a timing belt kit that has 2 pulleys and the timing belt for like 100$ and I found a water pump for 45$ or so. My other question is.... Do I need gaskets or seals or anything to put all this back together without leaking?
  10. Oct 30, 2011 at 8:38 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    Unless your cams seals or main seal is leaking then no. Water pumps come with gasket i have found a few that dont so.
    While you are in there change your belt tensioner also why you are in there.
  11. Oct 30, 2011 at 8:58 PM
    southerman21
    Dylan
    SE Ohio
    Ok, and it said one of them is an idler pulley and the other is a belt tensioner pulley.
  12. Oct 30, 2011 at 9:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yes you should do it. Its a belt just like all the others, not a chain. Change it. And water pump.
  13. Oct 30, 2011 at 9:18 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The belt is going to break sooner or later. Better to have it changed on your schedule than being stranded...
    Things that should be changed at the same time to avoid digging into the area again:
    Timing belt
    Idler pulley and tensioner pulley
    New bolts for the idler pulley and tensioner pulley
    Water pump
    Cam and crank seals
  14. Oct 30, 2011 at 9:21 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The 3.4 is a non interference engine. If the belt snaps, the engine will just stop running and you are stranded. This is not preferable, but besides the tow and inconveinence to you, the price to fix it is the same.
    I have heard of belts lasting 150K plus, and I have heard of them breaking at 90,001 miles.
    Personally, I would change it now. Walking sucks.
  15. Oct 31, 2011 at 4:36 AM
    southerman21
    Dylan
    SE Ohio
    Where do i find the pulley bolts and Where do u find the seals I don't want to get bent over by Toyota. They will prolly charge me 100 bucks a seal and 50$ a bolt!
  16. Oct 31, 2011 at 8:11 AM
    armyguy
    armyguy 2 in the head and you know their dead!!
    Co Springs
    03 Reg Cab 4x4 2.7 5 spd
    deckplate with afe pro dry, E3 plugs, royal purple in everything, Pioneer AVH-4300 Deck, Memphis audio in the doors, level kit, Custom shift knob, more to come!!!
    so is this for all engines or just the V6? I have 99K on my 2.7 4 banger and been trying to figure out if i should change mine or not...
  17. Oct 31, 2011 at 8:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not really, you have a timing chain. They last way longer.
  18. Oct 31, 2011 at 8:15 AM
    armyguy
    Co Springs
    ok sweet!!! thanks for the fast response:)
  19. Oct 31, 2011 at 8:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i wouldn't worry about it till like 175k or 200 i think
  20. Oct 31, 2011 at 9:36 AM
    KenLyns
    Belly of the Beast
    There are various places online that sell discounted Toyota OEM parts. There's http://www.villagetoyotaparts.com/ with their nice parts diagrams. I use http://www.toyotapartsource.com/ (run by Toyota of Dallas / TRDParts4U).
