Does TW use "bots" like reddit?
Discussion in 'Site Suggestions' started by Bertw192, Jun 7, 2021.
  1. Jun 7, 2021 at 2:16 PM
    Bertw192
    Bertw192 [OP] Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    As obnoxious as they can be... seems like it would be worthwhile to have a "bot" reply to some of the most common repeated questions:
    • Largest tire size
    • When to preform the first oil change
    • What does this button do
    • How to secure a bed mat
    • Where to mount a brake controller
    The bot could be triggered by key words and the reply could contain the most fruitful links for each issue, or multiple links, depending on the question. If the bot is off-base, then it would just be a matter of the OP ignoring the first response.
    Now mind you, I'm a computer idiot, so this question could be the equivalent of your grandparents asking you if it's possible to have the computer start your microwave... What I asked could be complete nonsense and I wouldn't hold it against you, if you told me that.
  2. Jun 7, 2021 at 2:44 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    We could try to catch the question before they submit it even. This is a good idea
  3. Oct 4, 2021 at 12:35 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    tonered likes this.
  4. Oct 4, 2021 at 12:44 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  5. Oct 4, 2021 at 12:53 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I realize the jest, but this is actually possible.
  6. Oct 4, 2021 at 12:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :confused:
    We jest not.
    xJuice[QUOTED] likes this.
  7. Oct 4, 2021 at 12:57 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Tacomaworld clippy:
  8. Oct 4, 2021 at 1:00 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Doing the Hunters Ed or Boaters Ed classes online, they ask you multiple choice questions, but every page has a countdown timer/wait time until you can go to the next page, so you really get to soak in the info and you can't just blast through the test. Something like that "could" work well
  9. Oct 4, 2021 at 1:00 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I can nearly promise you, you can't start my grandparents microwave with your computer. But I welcome you to try.
  10. Oct 4, 2021 at 1:01 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    What's the need and requirement?
    In my opinion the need is more on the moderation side.. preventing new users from posting the same tired old questions. Perhaps changing TW so you cannot start a thread until you've contributed/responded/asked in other existing threads?
    it seems that there's users that don't mind and respond to the same tired old questions (or do mind and give some random sarcastic answer) so I don't see that a bot is needed there. my 2c.
    / Full disclosure: I write bots for a living and would like to keep them out of TW and my truck.
  11. Oct 4, 2021 at 1:07 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    How about a "FAQ" button/ icon with all the frequently asked questions.
  12. Oct 4, 2021 at 1:11 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    That's basically the stickies that no one uses...
  13. Oct 4, 2021 at 1:20 PM
    Gen3TacomaOBX
    S
    In my opinion one problem with the existing stickies is that there's a long list of them AND the most important ones appear last so new users don't scroll down that area and see them.
    For example in the 3rd gen forum there is a sticky that says:
    ***Before posting anything in 3rd gen read this***
    But it is not visible unless you go looking for it. I feel it should be at the top (visible) and perhaps take a more stern tone like:
    ***DON"T POST ANYTHING UNTIL YOU'VE READ THIS!***
    my $0.02
    Bertw192[QUOTED][OP] likes this.
  14. Oct 4, 2021 at 1:21 PM
    AllTacosFloat
    Boston ish
    I know that, you know that. Don't underestimate the people. Some are lazy, dumb, looking for attention...whatever. one more option at the top wouldn't hurt.
    Bertw192[OP] likes this.
  15. Oct 4, 2021 at 3:46 PM
    Rastopher
    Ras
    Portland, Oregon
    I guess the question I'd be asking is: "Would a bot be able to help people who can't be bothered to google?". It's easy to believe something like a bot would have a positive effect, but you have to remember that you're not dealing with reasonable, thoughtful people.
    tonered likes this.
  16. Oct 4, 2021 at 3:49 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    After all the stupid shit i’ve asked, i try to fall on the newbie grenade questions as a way of giving back haha
    tcBob and Gen3TacomaOBX like this.
  17. Oct 4, 2021 at 4:46 PM
    Rastopher
    Ras
    Portland, Oregon
    I’ve definitely been there, and I totally get it. But at the same time, google has been around for a while now… Hell, I imagine it’s how 95% of us found tacomaworld. So we clearly know how to google?
    maybe we should try improving the sites search function, or add tagging to posts. God it’s gonna be embarrassing if we already have that…
    Gen3TacomaOBX likes this.
  18. Oct 4, 2021 at 5:09 PM
    ascendr
    ascendr Active Member
    To be able to stop/speedbump someone from posting, you would have to alter the source code responsible for handling all new thread posts and replies to existing threads (risky changes). A bot approach (as mentioned in OPs title) could just be a user account that parses all threads and replies with text or links to threads/stickies that might be helpful. In order for the bot to not suck you'd need to implement some NLP. If you want to get real fancy you can PM the OP providing the same info and asking if it answered his/her question. If they click yes, their original post/reply is deleted. Obviously bot account would need to have moderator privs for that to work.
  19. Oct 4, 2021 at 5:18 PM
    Gen3TacomaOBX
    S
    Has anyone here attempted to get assistance using Verizon's "Virtual Assistant" (mainly a chat window to a bot.) That thing absolutely SUCKS!
    You'd think with the deep pockets of VZW that they could engineer something less shaitty.
  20. Nov 6, 2021 at 8:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I think part of the reason for the over-asked questions is the fact that the TW search function is pretty worthless. Newbies try to use it, it doesn't bring up any of the relevant threads so they start a new one, not really their fault.
    Most of us regulars know that Google works best, as long as you type the word tacomaworld into the question.
    Maybe use a bot to tell newbs to use Google for searching :notsure:
    Jojee117, gwiz and Shveet like this.
