Does wheel size have an effect on towing stability?
Discussion in 'Towing' started by b_bednarz, Feb 12, 2018.
  1. Feb 12, 2018 at 6:00 PM
    b_bednarz
    b_bednarz [OP] Active Member
    Ben
    Phoenix, AZ
    2008 Super White DCLB Prerunner TRD Sport
    TBD
    Question for everyone here: I have been pondering about wheel size and towing stability. I have a 2008 DCLB sport with 17" wheels that I am slowly setting up for towing a 16'-20' down the road. I am considering a different wheel in the future since I am not crazy about the sport wheels. What is everyone's opinions on 16" vs 17" wheel for towing? Assume both would have a regular P- rated tire in stock comparable size. Would the extra sidewall result in a significant amount flex?
  2. Feb 13, 2018 at 2:26 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Negligible difference between a 17" or 16" IMO.
    I tow a 23ft travel trailer and am running 265/75/16 in a C load range on my truck. If you go with a passenger rated tire make sure you aren't over the load rating.
    b_bednarz[OP] likes this.
  3. Jun 6, 2018 at 4:43 AM
    flenniken7
    flenniken7 Wishin' I was Fishin'
    OKC
    2000 4x4 tacoma 1996 Z71 DD 248K, 2012 tahoe
    5100's 285' to come 4" lift 33's on hoe
    No, the overall weight and diameter of the wheel and tire combo will have some effect but its all relative, but going from a 16 to a 17 with the same or about the same size tire will make no noticeable difference
    lynyrd3 likes this.
  4. Jun 6, 2018 at 6:47 AM
    n1as
    n1as Well-Known Member
    2016 Tacoma DCSB TRD OR
    I notice some amount of "wobble" when I tow my ~4000 lb. travel trailer. The back of the truck just seems to wobble a bit side to side from time to time. It seems ever so slightly squishy. I suspect it is the softness of the P-metric tire side walls. If that is true, then more sidewall would be worse. In my case I plan to swap for LT tires which I think would make more of a difference than 17" wheels would.
