does your oil drain-plug GASKET come off with the plug or stick to the pan?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Jan 22, 2020.
  1. Jan 22, 2020 at 4:57 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Mine comes off with the plug. I put Teflon tape on the drain plug every time and have never changed the washer in four years, or in seventeen years of owning my old T-100. Using Teflon tape, I've never had a problem.
    I had a buddy that forgot to tighten his drain plug on a Ford Ranger years ago. It finally fell out and he lost all of his oil. Luckily, he's a pretty heads-up dude and realized the problem as soon as the engine started sounding different. He got a plug, refilled it and drove it for years after that without a problem.
    Moral of the story, Teflon tape would have helped in that situation due to the added friction, or at least that's what I want to believe. I use Teflon tape on all of my drain and fill plugs, transfer case, diffs, etc. I've also never had a problem with a plug getting stuck either. I chalk that one up to my use of Teflon tape too.
  2. Jan 22, 2020 at 5:00 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Heard of that on T-case and diff plugs that dont get changed very often. Seems like a good idea. Not totally sure its needed on the oil pan which should be changed semi regularly, but Im sure it cant hurt!
  3. Jan 22, 2020 at 5:11 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Mine usually sticks. I replace it every oil change.
    jungleman likes this.
  4. Jan 22, 2020 at 5:20 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Fumoto drain valve?
    jungleman and six5crèéd like this.
  5. Jan 22, 2020 at 6:33 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Yep
  6. Jan 22, 2020 at 6:59 PM
    jorgem
    jorgem Well-Known Member
    My drain plug washer has been stuck on the oil pan and reused for 48 oil changes. Never leaks.
    six5crèéd, Jimmyh and steveo27 like this.
  7. Jan 22, 2020 at 9:11 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Sticks to the pan every time.
    I’ve yet to replace it either. Just keep reusing it
    That said, I’ve changed the oil every 5k miles for the 90k miles I’ve owned the truck.
    It doesn’t leak and I have no intentions on replacing it either.
    six5crèéd likes this.
  8. Jan 23, 2020 at 3:39 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Duh, it sticks to the pan initially, then falls into the oil catch container. Isn't that how it's supposed to work?
    Alexely999 likes this.
  9. Jan 23, 2020 at 4:43 AM
    hdn4space
    hdn4space Well-Known Member
    FL
    2013 Silver SR5 4x4
    The only way to go!
  10. Jan 23, 2020 at 4:55 AM
    Markcal
    Markcal Well-Known Member
    I like your idea of using the PVC pipe rather than a screwdriver to remove the gasket, as I'm always worried I might gouge the oil pan.
  11. Jan 23, 2020 at 5:02 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    yup sticks almost every time. I probably have 3 or 4 old washers stuck on the top side of the skid plate, seems to end up there everytime i pop it off the pan.
    Someone mentioned pvc pipe, thats a good idea. get one with the id slightly larger than the washer and tap it sideways and it will fall down the pipe.
  12. Jan 23, 2020 at 5:19 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Well over 90% of the time it's sticks to the pan. I use my fingernail and pop it off so that it comes off when I take the drain bolt out.
    On a side note; I have taken it as a game in getting the bolt out with as little oil on my hand as possible. My best to date is just 2 fingers barely below the nails.
    The things we do to entertain ourselves...
    :rofl::rofl::rofl:
  13. Jan 23, 2020 at 4:01 PM
    t2ch
    t2ch Well-Known Member
    Travis
    Va.
    2015 TRD OR
    X2, my OCD cant handle that mess...
  14. Jan 24, 2020 at 4:19 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    To the original poster, sounds like getting old, and not being able to actually see the oil drain hole has you asking the question.
    As a suggestion, when the drain plug is removed, inspect it first for the sealing washer. If not there, once the oil stops draining, use your fingertip as your eye, and see if the drain plug area is smooth / flat, or you can feel the stuck sealing washer. Those methods should get you there.
    If uncertain, when you dump the drain oil from the pan into the sealed container to take o recycling center, just check the bottom of the drain pan.
    Just a thought and not attempting to be Mr Obvious.
  15. Jan 24, 2020 at 5:55 AM
    #35
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Sometimes it sticks, sometimes it doesn’t. I’ve reused my gasket like five times.
  16. Jan 25, 2020 at 11:17 AM
    #36
    ejl923
    Eric
    Western Mass
    No detail too small, its a good tip. I remember reading a similar thread where a guy was worried about the "flange" in the drain area, which turned out to be a stuck washer and put another gasket on top of the old. I also just reach up and feel for the lip, i cant get to it anymore.
  17. Jan 25, 2020 at 11:42 AM
    #37
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    Most of the time it sticks to the pan. I change the gasket every time. It really sucks to have a puddle of oil under the truck the morning after a oil change. Sucks even more to change the gasket once you realize it leaks.
  18. Jan 25, 2020 at 2:02 PM
    #38
    t2ch
    Travis
    Va.
    2015 TRD OR
    You guys realize for $34 you can put a Fumoto valve on and never worry about this silly washer again, right?
  19. Jan 25, 2020 at 3:05 PM
    #39
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Then how would silly threads like this ever get started?
  20. Jan 25, 2020 at 3:21 PM
    #40
    t2ch
    Travis
    Va.
    2015 TRD OR
    I’m sure something will come up.
