does your start up seem to take longer than it should?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by everleet, Mar 23, 2010.
  1. Mar 23, 2010 at 10:15 PM
    everleet
    everleet [OP] Well-Known Member
    NY
    07 SR5 TRD Off Road
    When I start my truck up, as it turns over, it seems to take just a second longer than other vehicles I have driven. Is this indicative of the truck?
    v6 2007 trd offroad btw
  2. Mar 23, 2010 at 10:16 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    you could seafoam it, usually helps out a bit, and clean your throttle body.
  3. Mar 23, 2010 at 10:16 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    ^I seafoam on a regular basis, if his is like mine thats just the nature of the beast.
    Mine does and it annoys the shit outta me. I sometimes get carried away and stop turning it right before it starts. Only to seem to take twice as long the second time.
  4. Mar 23, 2010 at 10:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yea mine does it too, it pisses me off cause my parents drive my truck sometimes and i always hear them not do it for the extra moment and the truck doesnt start
  5. Mar 23, 2010 at 10:23 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Every once in a while, my truck won't start. This ever happen to anyone else??? It turns over but just won't start. So I let it sit for a minute or so, and then try again and it fires up.
  6. Mar 23, 2010 at 10:23 PM
    bryandb
    bryandb Active Member
    Bryan
    MO Ozarks
    13 PreRunner V6
    I do it all the time. My truck is new and it gets to me almost as bad as the stability control. I have the habit of just bumping the starter when the truck is warm, like when I get gas and get back in after it only being off for a min. I think its the high compression because my vette did it too.
  7. Mar 23, 2010 at 10:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Here is the TSB for it. No start condition
    http://www.divshare.com/download/4099368-262
    Just had mine done.
    Here I broke it down.
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition Download Here Scroll down to find the code.
  8. Mar 23, 2010 at 10:32 PM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    Yea this is pretty normal. I actually PM'd chris4x4 about this and his response was that the ECU would not let the engine start until the oil pressure was up. IDK what sea foaming it has anything to do with the start up but i noticed that when i upgraded the oil to 10w-40 it mostly stopped doing it. Which makes me think chris is right. Im sure he will chime in any second and clarify what exactly is going on. Anyways, appearantly 7-10 turns is normal for most Tacos. If youre within that range i wouldnt worry about it.
  9. Mar 23, 2010 at 10:33 PM
    Canadianboy
    James
    Vancouver, BC
  10. Mar 23, 2010 at 10:33 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    How do you seafoam, or rather, what do you seafome? Is there a write up on this somewhere?
  11. Mar 23, 2010 at 10:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I just learned about it myself last week.
    For those interested go here.
    http://www.tacomaworld.com/forum/sea...earchid=269104
  12. Mar 23, 2010 at 10:56 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Normal
  13. Mar 24, 2010 at 11:47 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    Could be your battery? I know that is my problem!
  14. Mar 24, 2010 at 12:19 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    My 4-cyl does the same thing, around 5-7 spins before it fires up. This is a little more cranking than other FI vehicles I've had but does not seem excessive. (What bothers me more is the hanging high RPM on cold start.) Carbureted vehicles typically will fire with a bump of the starter once they are warmed up.
  15. Mar 24, 2010 at 12:23 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    Mine does.... took a while to get used to it, but I don't even notice any more.
  16. Mar 24, 2010 at 12:25 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    That's true. I've noticed that it isn't near as fast as my Escape.
  17. Mar 24, 2010 at 1:26 PM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    That TSB doesn't answer why my truck has done it. I have no JBL system, and even if I did it would already have the new updated amp.
  18. Mar 24, 2010 at 2:43 PM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    My truck starts fine.
  19. Mar 24, 2010 at 2:47 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    thats normal.ive had 5 toyota pickups and everyone does it. even brought my 02 back to dealer at the time and they claim its normal. not sure why it does that.
  20. Mar 24, 2010 at 3:12 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    had my truck for over two years and it catches me every now and then
